Question about Garden
How to remove chainsaw clutch - Garden
  • 252 Answers
Hi
remove statrer cover assy
remove plug, rotate engine until piston @ bdc - insert a thick 6 mm nylon starter rope through plug hole and rotate piston so that it pushes rope in between piston and cylinder top this locks the crankshaft
its called a soft stop
take a punch and hammer and give the clutch 1 or 2 hits in and clockwise direction clutch should loosen
to refit clutch , remove soft stop and rotate engine counter clockwise fit the stop and jamb it again between piston and cyl head then spin on the clutch ( threads are left hand ) use punch and give 1 or 2 hits to tighten again - remove soft stop and refit plug and starter cover assy
clutch should tighten further when engine runs
cheers paul
hope it helps
Posted on Aug 03, 2010
How do I remove the clutch cover from a Ryobi chainsaw?
There are two nuts that hold the clutch cover and chain bar in place. The same nuts you would loosen to adjust the chain tension. Once those are taken off the cover, bar and chain can be removed.
Sep 03, 2016 | Ryobi RCS3535CA 14-inch 35cc Petrol...
Clutch removal on a580-531060 craft an chainsaw
Assuming you want to remove the clutch spider, which typically is left-hand threaded onto the crank. Not knowing if it's an internal (chain drive sprocket is "outboard") or external clutch, here goes for both. After removing bar & chain.
Internal: CAREFULLY (so it doesn't fly) remove clip from crank, remove washer, clutch drum, bearing and/or rim sprocket. Remove recoil starter. Using proper tool to fit clutch "spider" and impact wrench, turn it CLOCKWISE with wrench to unthread it.
External: Remove bar & chain and recoil starter. Using tool to fit the clutch "spider" and socket on impact wrench, spin the spider off CLOCKWISE. You can then remove remainder of clutch & bearing.
Be sure to grease the bearing while it's accessible.
Starter removal avoids applying any load if the crank turns.
Jun 05, 2016 | Garden
Chainsaw clutch adjustment
To my knowledge chainsaws do not have an adjustable clutch. They can be replaced. To replace you must keep the piston from moving. I have stuffed some rope into the spark plug hole and then remove the nut holding the clutch in place. Then use a puller to remove the clutch from the shaft. There should be a key in the shaft so watch for it and put it back when you put the clutch back on.
Oct 29, 2015 | Garden
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
How do I remove the clutch plate from a Yukon 52cc chainsaw
You turn the clutch clockwise. There should be an arrow on the plate. As always be gentle. GOOD LUCK FRIEND.
Sep 21, 2014 | Garden
How do you remove the clutch on a 025?
remove spark plug.
block ther piston with a piston stop.
remove clutch drum exposing the clutch
it has to be turned clockwise to remove it. 19m socket
Sep 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Husqvarna 244RX
the clutch should unscrew
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 16, 2013 | Husqvarna 250ps 244rx 36r Ps50 250r 250rx...
Chainsaw clutch removal
All Husqvarna chainsaws have the clutch spun onto the crankshaft with a left hand thread, this makes them self tightening, if there is a nut as part of the clutch centre you can use a socket and speed brace to jat the clutch off against compression, a impact wrench works great for this, if there is no nut there will be a special tool for it, it depends on the model as to which tool you need,
Oct 17, 2012 | Husqvarna Garden
How do i remove or change the clutch on my Poulan model 3314 chainsaw???
Remove cover,chain,& bar. Hold crank and turn clutch counter clockwise to remove.Replace in reverse order.
Mar 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
404 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
