Question about HP OfficeJet T45xi All-In-One InkJet Printer
I receive a "Cannot connect to PC" when I try to scan using my HP OfficeJet T45xi printer/fax/scanner/copier using Windows XP Home Edition with SP3 on my Dell Inspiron 600M. I have downloaded and run the ojT_ENU_xp1305.exe which is an HP published Windows XP drivers file. I can print but there also seems to be a problem with printing in color. Are there any compatible device drivers from other HP products that help circumvent these issues by installing them?
  • HP Master
  • 5,524 Answers
That is the correct driver.
Make sure you have a good cable (with bidirectional support). Check that the ECP mode is enabled for the parallel port in the Device Manager. Click Start > Properties (Control Panel). Click on the Hardware and then the Device Manager. Open the Ports section and look for the parallel port option (LPT1). Double click on this and look at the Resources tab. If the printer is connected in ECP mode, you will see two entries for the I/O ranges. This may need to be enabled in the BIOS (often reached by hitting F1 or F2 when restarting the computer before the OS loads). If you adjust the BIOS setting for the port, you will need to return to the Device Manager and adjust the Port Settings to Enable Legacy Plug and Play.
If you use a USB to parallel adapter, make sure you got one that supports bi-directional communication.
I hope this helps.
Posted on Aug 02, 2010
I am using windows xp and I am having problems scanning using HP officejet L7590. I can print with no problems
http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/3643611.pdf
this is an user manual ..complete edition ...save it ...and read it well .cause if you can print it means that isnt a driver problem ...but just your skils with it ...I hope this will in-light ya ...
Jul 18, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  2. Click Paint .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
I cant scan!
Resolution : I
1 Scan using Windows Fax and Scan
  • Click New scan .
  • Click File , and then click Scan .
  • Option two: Scan using Paint
    2. Click Paint .
    4. Click Scan .
    II nd issue :
    Problem :
    'An error occurred while communicating with scanning device' Message Displays in Windows Vista When Scanning
    Then refer to
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01290511&cc=us&lc=en&dlc=en&product=441125
    Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
    New computer with Windows Vista
    I have my HP OfficeJet T45xi working with Vista Ultimate. I used a cable coverter to switch to USB. I must install the printer with the USB cord unattached. Install as T40xi whose driver comes with Vista. Set to USB port 1 or 2. Plug USB into USB port 1 or 2 (only ones of six USB ports that worked for me). When Windows discovers the printer do not let it install the printer and tell it to not try again.
    Works for me. Hope it helps you!
    Feb 03, 2008 | HP OfficeJet T45xi All-In-One InkJet...
    Scanner Failure: HP Officejet 6210
    After hours of trying things.I found this and it worked. The scanner button doesn't work, but at least I can scan.
    ?id=microsoft.windows.resources.expandarrow To scan a picture using Windows Photo Gallery
      Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
    1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Windows Photo Gallery.
    2. Click File, and then click Import from Camera or Scanner.
    3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
    Jan 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet T45xi All-In-One InkJet Printer Logo
    152 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
