Question about Whirlpool Calypso GVW9959K Top Load Washer
The screen shows F26, is there any thing i can do
  • 15,935 Answers
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Posted on Sep 28, 2010
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
What means the code error F26?
F26 Boiling protection. The program is interrupted and the drain pump is operated. The display shows Technical fault F26. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
Temperature at NTC temperature sensor has exceeded 194?F (90C).
Remedy:
Check the heater relay and replace it if necessary.
Cause:
NTC temperature sensor providing inaccurate information.
Remedy:
Replace the NTC temperature sensor.
Cause:
Heater relay closed.
Remedy:
Replace the heater relay.
Aug 25, 2014 | Dishwashers
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Jun 16, 2014 | Whirlpool duet Washing Machines
F26 code
Unplug it and wait a while, the door may finally release the lock. Then google the problem to see what F26 is.
Nov 25, 2013 | Hotpoint Ultima WD72 Front Load...
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
F26 (on an HE5t)
This is most likely a problem with the door switch or a loose connection at the switch.
Jan 16, 2011 | Washing Machines
What does F26 mean
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Sep 11, 2009 | Washing Machines
F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
53 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
