Question about LG LDF9810ST Built-in Dishwasher
I have a LDF9810ST that I'm trying to replace a broken drain line. The old part number is AEM39700301 and the new part number is AEM69493803. The new part is made with a plastic u-shape plastic piece with a black hose that comes off the top of the u-shape plastic. Where does the black hose go?
Hey Glenn. Did you ever figure it out? I am about to replace my mother's hose since it cracked and I am looking at the service manual -but am I little stumped. I don't have the dishwasher in front of me with the part so I can't explore the options.
Also, where did you buy your part? Looks like Repair Clinic is one of the few places to have it in stock. $36.. ouch!!!
Tried to replace it with a universal model from Home Depot and it doesn't fit. Seems the LG uses a smaller outlet on the pump than others AND they have engineered a one way valve in the hose instead of the pump..
I have the same model and am just waiting for the fun to begin on mine too.
I will guarantee you that I will NEVER purchase another LG appliance again. Between non standard parts and crappy reliability, it's been a very poor customer experience to date.
Posted on Dec 20, 2010
How to replace gas lines on the tb146ec cultivator.
Hi Robert:
Sounds like a matter of removing the old lines and installing new ones.
Work safe! Drain fuel from tank first.
May 03, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Water not draining and a e0 is flashing
http://www.fixya.com/answer/answerpageslideview.aspx?thid=24072807&ctg=131&brd=474
Mar 26, 2014 | LG LDF9810ST Built-in Dishwasher
Our LG dishwasher makes loud noises during the wash cycle. It rumbles like the machine is being rocked by an internal force. Could it be a problem with the plumbing? It happens for about 20 minutes of...
You may have a model which qualifies for a no cost service upgrade. Contact your local LG servicer with the model and serial number. They may replace the sump (AJH31248604) a drain hose (AEM69493803) and a guide assemble (4975DD1001), depending on model and serial number. (some even may get a control board)
May 17, 2011 | LG Dishwashers
How do I install a new drain hose in my LG dishwasher the original cracked and flooded my floor
You will have to completely uninstall the dishwasher to replace the drain hose assembly.
Part# AEM69493803.
Once the unit is out of the cabinet drain hose replacement is fairly easy.
Jan 14, 2010 | LG Dishwashers
I have an LG Dishwasher model LDF9810ST. Error code E1 keeps showing (Water Leakage Problem) NO water problems anywhere to be found. I have a hard time shutting down the machine. It has had a new MAIN...
Are you draining the unit in the basement or under the kitchen sink?
If you are draining the unit to the floor you will need a new drain hose with a syphon breaker. This drain hose is factory installed on all new LG dishwashers.
The part # is AEM69493801
This is a known issue and may be covered under your factory warranty.
Depending on where you live a factory service tech may be in your area.
Could you explain the second problem further...Hard time shutting down?
Shoot me a E-mail @ omaharox@msn.com.
I am a LG factory service technician not a sub contractor.
Mike
Jan 08, 2010 | LG LDF9810ST Built-in Dishwasher
Kenmore series 80 washing machine won't agitate or spin
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
Will not come on.
Since the LG LDFxxxx family, including the 9810 all have a power button (and not just a door handle interlock switch that turns the unit on when you close the door, you have an internal problem that will not have a quick fix.
This dishwasher had a 12 month parts and labor and a 24 month parts-only warranty. If you have proof of purchase, I recommend you contact the LG support number in the owner's manual.
Good Luck!
May 24, 2009 | LG LDF9810ST Built-in Dishwasher
Kenmore 700 Series Top Loader Washer "tub or barrel" does not spin
The symptoms you describe sound typical of a broken motor coupling. The coupling is located between the gearcase (transmission) and drive motor and consists of two plactic pieces and a rubber bushing. Symptoms of a broken coupling include a washer that will fill, but will not agitate or spin. It will, however, still drain. You may also find black filings under the washer if the rubber bushing sheared apart. If these symptoms sound familiar, then click on the following link for step-by-step instructions on how to replace:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Many of the original couplers that came from the manufacturer were all plastic. They would commonly fail after repeated use, by a weakening of the center hole. The hole would either round out or develop cracks. Eventually the coupler would snap. The fix was a new and improved coupler with a steel grommet. The provided link includes the part number you need to order. A replacement coupler can be found at searspartsdirect.com under the "Brake/Clutch/Gearcase/Motor/Pump" heading as item number 13. Use the illustrations provided by Sears for assistance. You can also try repairclinic.com to order parts as well. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. This IS a common part they do carry.
I hope you find this information helpful. If you require additional assistance please let me know. If the symptoms I've described do not match yours, post back and elaborate further.
PS Thank you for posting your complete model number. It makes our job much easier in trying to find a solution for you.
Sep 01, 2008 | Washing Machines
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Jan 14, 2008 | Washing Machines
LG LDF9810ST Built-in Dishwasher Logo
248 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
