Question about Lincoln Ovens
What does LP FAIL and RP FAIL mean, I have a 1600 series model pizza oven.
5 Suggested Answers
  • 125 Answers
SOURCE: bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 7 Answers
SOURCE: i need parts for a 1300 series lincoln pizza oven
A.I.S. appliance installation buffalo ny
Posted on Dec 02, 2009
SOURCE: KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Posted on Dec 30, 2009
  • 195 Answers
SOURCE: Blodget Oven
I dont have th error code near by , truck is on the road but if i remember that was a bad element shorted !
Posted on Dec 08, 2011
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Pizza dough spilled into top of oven.
Pizza sauce tends to be highly conductive and corrosive. If it got into the keypad or control board it is probably causing a short. It may be able to be carefully cleaned with alcohol but some disassembly is required.
Jun 26, 2010 | Fisher and Paykel AeroTech - OS302M...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Gas conversion kit
If the manufacturer can't or won't supply one, check with your local LP gas supplier, if they dont do this type of service they can likely refer you to someone who can, This is not a typical "do it yourself" type project, if its to be used in a commercial application, an unapproved conversion may render the oven unsafe to operate causing a structure fire and bringing down the wrath of your local fire martial.
Aug 15, 2009 | Lincoln Conveyor Oven - 1133-000-A
A loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Jul 15, 2009 | Ovens
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Blodget Oven
did they sell you a broken one?
Jul 05, 2008 | Blodgett DFG-100 Gas Single Oven
Lincoln pizza conveyor oven
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
Dec 03, 2007 | Ovens
Ovens Logo
248 people viewed this question
Top Lincoln Ovens Experts
Colin Stickland
Colin Stickland
jasbo
jasbo
Mike Teter
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
