Question about Zoom 220 HMV 3-Wheel Travel Scooter
Scooter speeds up or stops, sometimes won't take off from stop, sometimes works just fine
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi please rate me thumbs up 1 to 4 as you feel i have helped,i help as i care not for profit,im disabled myself.my opinion it could be a loose connection on batteries,the throttle pot [what the throttle is connected to] the speed control pot [what the speed volume connects to] if fitted.loose conections to any of them or worn or dirty motor carbon brushes,or carbon brush spring.i hope this has been of help.also you could try downloading the PDF File Troubleshooter on ur product with Adobe Reader.
Posted on Aug 02, 2010
Testimonial: "thank you"
2007 Peugeot Ludix will not start when hot
Hi, Rod and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. HISS light not going off.
5. Faulty starter motor.
6. Valves adjusted too tight.
7. Spark plug gap too wide.
8. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.apriliaforum.com/forums/showthread.php?174841-My-scoot-won-t-start-sometimes-when-engine-is-warm
Scooter Troubleshooting Scooter won start All about Scooters
PEUGEOT Ludix 4T Workshop Manual
Peugeot LUDIX 10 ONE 50 cc 2004 Parts
http://www.full-of-grace-and-wine.com/peugeot/peugeot_satelis_125_owners_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 25, 2018 | 2008 Peugeot Ludix 2 Trend
Scooter keeps stopping randomly. The battery level near to the speed lever drops quickly to red, scooter stops. Turn it off then on again and fine for a bit - then same happens?
These units are 24 volt systems. If the voltage at the controller drops below 18 volts the controller will cut out. Shutting the unit off and back on resets the controller. Since your battery gauge is dropping into the red when accelerating your batteries are suspected to be bad. If the batteries LOAD test fine then check your battery harness and circuit breaker wiring for a loose and / o r hot connection after riding it.
Oct 28, 2013 | Hurricane Pride Pmv Mobility Scooter Candy...
Singer stylist 534 sometimes when you stop won't start without turning balance wheel
Yes this is normal especialy with heavier fabrics. It allows more control so you build up speed gently. It is also related the limited power of the motor.
Mar 01, 2013 | Sewing Machines
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
Zoom 220 HMV 3-Wheel Travel Scooter Logo
202 people viewed this question
Top Zoom Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Craig Butler
Craig Butler
Are you a Zoom Health and Beauty Expert? Answer questions, earn points and help others
