Question about Maytag MSD2656G Side by Side Refrigerator
Trouble shooting defrost system
Maytag side-by-side refrigerator Model:MSD2556.
Question: What is the procedure for manually making the refrigerator go into the defrost mode. It has the solid state module that controls the defrost (not the older defrost timer).
  • 1 more comment
  • Allena33 Apr 29, 2008
    On a Maytag, to put the adaptive defrost board into defrost cycle/mode, short "L1" and "Test" on the board with a small screwdriver and wait three seconds. You should hear a clicking noise from the relay and the fridge cooling/freezing cycle will shut off and go through a defrost cycle.
  • John2804 May 12, 2008
    Freezer section cools properly. Refrigerator section is barely cool. I've checked the air duct passage between the freezer and the frig and it is clear of any ice build-up or any other obstruction. What's next.
  • panzadebagre Jan 23, 2009
    Whirlpool side by side. water ice dispenser. the freezer is icing up and then doesn't stay cool long enough.
    Genius:
  • 1,073 Answers
You can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Posted on Apr 25, 2008
Defrost board
I am not sure about the question you are asking but yes the model MSD2556 Click here=> MSD2556AES Controls location 13 in that photo is your=> 61005988 Defrost Control Board
A parts list with this part can be found on page 2 and 3 of the MSD2556AES Parts Manual PDF for other manuals click HEREIf you have questions please let me know, Thanks Sea Breeze
Nov 20, 2012 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Hello, the refrigerator side is not cooling, but the freezer is working perfectly. Our fridge is 26 cu instead of 25.6
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
My refergerator / freezer is not working. The fan is blowing but there is no cold air coming out
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Fridge is not staying cool after defrost--only stays cool for a couple of days then stops cooling until we defrost again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
The freezer doesn't freeze, and fridge doesn't get cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 02, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 28, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
ICE MAKER NOT GETTING WATER FOR ICE BUT THE DOOR UNIT WORKS
I had this problem and eventually traced it to the water freezing in the fill tube in the freezer.  I defrosted the tube and no more problem
Jan 18, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
385 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
