Question about Hammering
NFPA Specs for electrical in homes
What are the National Fire and Protection Associations Specifications for electrical in new homes?
  • 760 Answers
NFPA 70 NEC2008 is adopted in most states. There are a few that are still NFPA 70 NEC2005
Posted on Aug 13, 2010
Need 115 or 230 volt wiring diagram
Perhaps you do... but you will need to FIRST share more information... certainly to me.
I have been doing electricity professionally for over 50 years... exotic large scale industrial... and small time home and EVERYTHING in between)... Loved every bit of it.
However... there are CERTAIN & appropriate codes... and a little information in lieu of ALL the NECESSARY information can be quite deadly... for reals!
When the Nutone Heater-Vent-Lite first came out... I figured an elegant solution to keep the existing lights... (utilizing two hot wires + one neutral + one ground (14 gauge, 15 anp 3way with ground)).
Yes it can be done... but if you want a serious answer... you will have to clearly state what fan... model and application... and I might entertain your problem... in light of NATIONAL ELECTRICAL CODES... unless you assure me you are outside the NEC purview .. and hold EVERYONE ELSE... ABSOLUTELY & TOTALLY HARMLESS... Indemnifying all the world.. but for yourself.
If you had asked... can that old fashioned Nutone be put on 14 gauge wire... I would have said certainly... but recent CODES no longer allow that fan to be used without a HUMIDISTAT... (whole-house fan system).
and even that MIGHT WELL BE ARGUABLE with YOUR LOCAL ELECTRICAL ENGINEERS / INSPECTORS.
national electrical code 2014
http://www.amazon.com/NFPA-70®-National-Electrical-Code®/dp/1455906727/ref=sr_1_1?
Wiring Simplified: Based on the 2014 National Electrical Code® Fourty fourth Edition > http://www.amazon.com/Wiring-Simplified-Based-National-Electrical/dp/097929455X
NEC-2014-National-Electrical-Code
NEC 2014 National Electrical Code 2014 NFPA 70 Anglais Broch 1 octobre 2013 NFPA 70 National Electrical Code NEC 2014 Edition 1st Edition
Jan 20, 2016 | Dryers
Tip
Important industry standards for chute systems and compactors
Important industry standards when installing chute systems and/or compactors are the International Building Code (IBC), the National Fire Protection Association Guidelines (NFPA), the Underwriters Laboratories (UL), and the Authority Having Jurisdiction (AHJ). Each of these standards are put in place to maintain the highest level of workplace safety, which the Colorado Chute Company will never compromise on these standards. http://coloradochutes.com
on Nov 17, 2016 | Miscellaneous
Tip
AFCI-GFCI Circuit Breakers - Your Home’s Electric Service has Never Been Safer
Would you ever consider driving a vehicle without functional brakes? Probably not. Driving such a vehicle is simply too dangerous and yet the majority of Americans do something every day that is potentially more dangerous than driving a car with no brakes. We live with home electrical service that is not nearly as safe as it should be. As a result, thousands are killed or seriously injured by electrical malfunction, electrocution and electrical fires every year. What's even more alarming is that most homeowners are unaware of this sobering fact or assume making their home's electrical service safer is unaffordable. Thankfully a recent breakthrough in residential electrical service technology is making it easier and more affordable than ever for homeowners to protect their families from electrocution, electrical fires and other deadly electrical safety hazards.
The Problem with Your Home's Electrical Service
The majority of homes in the U.S. today are approximately 40 years old and unless they have had their electrical service updated to the latest National Electric Code (NEC), they contain either fuses or traditional circuit breakers in their electrical panels. While fuses and circuit breakers look and function differently, they both serve the same purpose. They interrupt the flow of electricity to a circuit in your home if they sense an overload or electrical short.
For decades fuses and circuit breakers have been the main electrical safety component of most home electrical services. The problem with traditional fuses and circuit breakers that most people are unaware of is that they don't provide protection from some of the most common and most deadly of residential electrical hazards, electrical fires and electrocution.
The National Fire Protection Association (NFPA) reported that in 2011 that nearly 2000 people were killed or injured in home electrical fires alone. This doesn't include the countless others killed or seriously injured as a result of accidental electrocution. What's worse is that most homeowners are unaware that almost all of these deaths and injuries can now be prevented by an inexpensive and revolutionary new type of circuit breaker, known as the AFCI/GFCI or Dual Function circuit breaker.
What are Arc Faults and Ground Faults and why are they so dangerous?
The acronym AFCI stands for Arc Fault Circuit Interrupter and this device is designed to cut the flow of electricity when it senses an arc fault. If you have ever plugged in an extension cord or flipped a light switch and heard a loud popping sound, then you have experienced an arc fault. The sound that you hear is actually electricity jumping from one electrical contact in the plug or switch to another. Though this might seem harmless, an arc fault causes an excessive amount of heat in your home's wiring which, over time, can actually melt the wiring's insulation leaving the wire exposed. This can lead to an electrical fire. Since the majority of your home's wiring is hidden behind its walls, it's almost impossible to know if your home is at risk.
GFCI stands for Ground Fault Circuit Interrupter. Much like an AFCI, a GFCI is designed to cut the flow of electricity to a circuit; however a GFCI is triggered not by an electrical arc, but rather a ground fault. This is when electricity travels outside of its intended path as it tries to find the shortest path to ground. An example of this is when a person with a live electrical wire touches the ground or something resting on the ground that can conduct electricity. The electrical current will travel through the person's body as it seeks the shortest path to ground, electrocuting them in the process. It only takes 1/10 of an amp to kill a human being. To give you an idea of just how little power that is, the average 60 watt household light bulb draws 5 times the power needed to kill a person.
Why are these dual function AFCI/GFCI circuit breakers so important?
Prior to the development to the AFCI/GFCI circuit breaker if the NEC called for a specific area in the home to be AFCI and GFCI protected, typically laundry rooms and kitchens, to have both AFCI protection and GFCI protection electricians had to use a GFCI outlet and an AFCI circuit breaker to meet this requirement. The problem was that this was rather inefficient and troublesome, especially when the circuit was tripped because the homeowner had to check both the outlet and the circuit breaker to see which had tripped and then reset it. Not only does the dual function AFCI/GFCI circuit breaker eliminate this problem, it also provides better protection and can be installed on every circuit in your home quickly and easily for ultimate protection. Residential Electrician
on Jun 05, 2015 | General Electric Electrical Supplies
Unimac front loader washer with the error code OF not sure what it means. This is a stackable unit.
[PDF]Operation/Maintenance for Drying Tumblers - Alliance ...
docs.alliancelaundry.com/tech_pdf/Production/70283501en.pdf
NFPA 54 "National Fuel Gas Code" and Standard ANSI/NFPA 70 "National Electric Code." In Canada ..... NOTE: If display shows an error code, refer to.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
65 lb Capacity UWN065T4V - UniMac
unimac.com/products/unimac-washer.../high.../65-lb-capacity.aspx
A description for this result is not available because of this site's robots.txt - learn more.
e OP error - YouTube
Dec 15, 2015 | Washing Machines
Fuel gas code ANSIZ223.1 or CAN/CGAB 149 the GUK125020-3a serial #8499f46215 and #8499h10894 125000 btus
[PDF]SECOND DRAFT REPORT - NFPA
www.nfpa.org/.../AboutTheCodes/.../...
National Fire Protection AssociationJan 3, 2014 - NFPA 54®, ANSI Z223.1-2012 National Fuel Gas Code, 2012 Edition ....ANSI LC 1/CSA 6.26, Fuel Gas Piping Systems Using Corrugated
Jul 26, 2015 | Grilling
Where should I install a smoke detector?
The National Fire Prevention Association (NFPA) states that the best location for a smoke detector is on the ceiling near a doorway or stairway.You should also have a smoke detector on the hallway ceiling outside of sleeping areas (bedrooms). Put one either inside or just outside the kitchen.
May 09, 2013 | Home
Trying to change plug from a 3pronge hookup to a 4.The dryer only has 3 wires to hook up extenstion plug has white,red,black,green ...what do i do
It is your responsibility
 To contact a qualified electrical installer.
 To be sure that the electrical connection is adequate and in
conformance with the National Electrical Code, ANSI/NFPA
70-latest edition and all local codes and ordinances.
The National Electric Code requires a 4-wire supply
connection for homes built after 1996, dryer circuits involved
in remodeling after 1996, and all mobile home installations.
A copy of the above code standards can be obtained from:
National Fire Protection Association, One Batterymarch Park,
Quincy, MA 02269.
 To supply the required 3 or 4 wire, single phase, 120/240 volt,
60 Hz., AC only electrical supply (or 3 or 4 wire, 120/208 volt
electrical supply, if specified on the serial/rating plate) on a
separate 30-amp circuit, fused on both sides of the line. A
time-delay fuse or circuit breaker is recommended. Connect
to an individual branch circuit. Do not have a fuse in the
neutral or grounding circuit.
 Do not use an extension cord.
 If codes permit and a separate ground wire is used, it is
recommended that a qualified electrician determine that the
ground path is adequate.
Electrical Connection
To properly install your dryer, you must determine the type of
electrical connection you will be using and follow the instructions
provided for it here.
 If local codes do not permit the connection of a neutral ground
wire to the neutral wire, see "Optional 3-wire connection"
section.
 This dryer is manufactured ready to install with a 3-wire
electrical supply connection. The neutral ground wire is
permanently connected to the neutral conductor (white wire)
within the dryer. If the dryer is installed with a 4-wire electrical
supply connection, the neutral ground wire must be removed
from the external ground conductor screw (green screw), and
secured under the neutral terminal (center or white wire) of the
terminal block. When the neutral ground wire is secured under
the neutral terminal (center or white wire) of the terminal block,
the dryer cabinet is isolated from the neutral conductor.
 A 4-wire power supply connection must be used when the
appliance is installed in a location where grounding through
the neutral conductor is prohibited. Grounding through the
neutral is prohibited for (1) new branch-circuit installations,
(2) mobile homes, (3) recreational vehicles, and (4) areas
where local codes prohibit grounding through the neutral
conductors.
Sep 23, 2011 | Estate EED4100SQ Electric Dryer
Could you please tell me what are the installation specifications to install a freestanding pot belly stove
The specifications depend on where you live or want to install this stove. If you live in the U.S, U.K. or A.U., and the stove doesn't meet the new or current EPA, NFPA Standards or your home owners insurance standards, you can't install or use it. Here's the common rule of thumb, if the stove is 10 years or older, it won't meet the standards. It's best to check with your area's local officials, before installing it.
Apr 06, 2011 | Heating & Cooling
What is a "r-fault recepticle" - this is an
It refers to arc-fault protection. If you google arc-fault you will get many hits including some of the standard sites such as:
http://www.cpsc.gov/CPSCPUB/PUBS/afcifac8.PDF
http://en.wikipedia.org/wiki/Arc-fault_circuit_interrupter
http://www.nfpa.org/assets/files/PDF/Electric/Arc-Fault_Circuit_Interrupters.pdf
You will want to check with your local building department or inspectors to see if they have adopted the code revisions that require them or not but even if the haven
Nov 17, 2010 | Electric Hammering
Hammering Logo
128 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
