Question about Hoover Washing Machines
My Hoover VH W 964 DP 37 show E11 error code. What does that meen? No explaination in the manual.
5 Suggested Answers
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
SOURCE: I have a Hoover vhd sensor Dry Washer Dryer and
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Posted on Oct 03, 2010
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
SOURCE: error code E11 on hoover
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
Error E11and washer does not wash .
dont know bout the code but I would suggest u check the water pressure switch, and or the door switch
Jun 11, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
WHAT does E11 meens washer does not take in water
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF705BZHS, is not filling with water and showing an E11 error code. The E11 code means that your washer is taking a long time to fill. First, make sure that the incoming water faucets are turned on. Next, you will want to make sure that the pressure is above 30 PSI. I suggest resetting your washer, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
Hoover washing machine manual
HOOVER DYN 10144 DP What does it mean ERROR E13 CODE
Mar 01, 2014 | Hoover Dishwashers
Hoover wdyn 9666pg-80 error code E11
I fixed ours! here is a video of how i did it, it shows where the wire snaps and what part the wire connects to:
May 11, 2012 | Hoover Washing Machines
I purchased this machine last year now after ending the programme i.e.washing door is not opening and it is showing error 14. Could u please help me out. Regards
Hi.
The fault E14 on Hoover washers indicate a problem with the heating circuit. Element, Thermistor and Central Control unit must be tested.
About error codes and troubleshooting Hoover appliances see the links below:
Hoover After Sales Service - Online Fault Finder
(Hotpoint/Creda/Indesit/Ariston Error Codes)
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
The sellers apply to USA market. Elsewhere see your local hoover distributor.
If you need to call a technician ring the customer service number listed on the owner manual or check your local Hoover website.
Regards.
Ginko
Sep 15, 2011 | Hoover Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
Dec 20, 2010 | Washing Machines
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
Washing Machines Logo
316 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
