Question about Garmin GPS
Power chord loose connection for 2720 on back of unit
I just need a new power chord.
Posted on Apr 29, 2008
Garmin 2720 keeps dropping the satellite connection
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work.
May 26, 2010 | Garmin StreetPilot 2720 GPS Receiver
Unable to update unit
When you plug in the USB cable, if your System, Hardware, Device Manager lists "GARMIN Devices", then the problem has to be in your network connection or Garmin WebUpdater. If your Device Manager doesn't list "GARMIN Devices" then the problem is in the computer, USB cable, or 2720.
I have three 2720s right now with bad USB ports. I'm going to try replacing the USB driver chip in each unit, but now I'm just guessing. Hope this helps. Tom
Dec 30, 2008 | Garmin StreetPilot 2720 GPS Receiver
FIXED! Garmin 2720 Power Cable Defect
Thank you for the tip. Sorry for the trouble you had.
Mar 01, 2017 | Garmin StreetPilot 2720 GPS Receiver
Fails to start
the problem is your fan may not have got proper power supply....the wire connecting the fan and power chord should be perfect....if there is a loose connection your fan may not get proper power supply and then it will not run.....this is the main probem.....just check the wire connection between the fan and power chord has been properly connected and there are no loose connections....i am a software engineer....and have experience in it....try this ...it will 100% solve your problem.......
Sep 19, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Problem power chord
The problem that you Actually Have, Is that the Mains In DC Jack on the Motherboard. Has worked Loose.
You need this replacing A.S.A.P as it,s burning your power packs out, it,s also possibly arcing across the motherboard.
If you look on the internets largest Auction Site :) services are offered to repair these. Usually varying From £40-$80. Plus, Dependant on sending the complete laptop, or just Motherboard.
Alternatively A Computer repair centre. I,d estimated £100-$200 Maximum. But worth Doing to save your Motherboard And future power pack purchases.
Mike @ Compurepair.
Jun 26, 2008 | Acer Aspire 1642WLMi Notebook
WILL NOT RUN (KSM90WW)
theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
May 01, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Power
hi,
try this
> connect the power chord directly to the wall socket.
> check with different wall sockets.
> unplug and plug in back the power chord. make sure that it is securely plugged in.
> check whether there is a light on the box which comes between the printer and the wall socket.
> if there is light and you hav the problem u need to service the unit else power chord may be the problem.
thanks and regards
agnel
Feb 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
134 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
