Question about Gateway 504GR PC Desktop
I have a Gateway 504GR. My cooloing fan has
I have a Gateway 504GR. My cooloing fan has become noisy. Is it a 90mm or 92 mm fan? Thanks
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
What is the proper rpm for the 80 mm cooling fan and also the 90 mm cooling fan for the HP Amd Athelon II? I am trying to diagnose this with a monitoring software package. It tells me what the rpms are...
Trace the power wire from the fan back to where it connects to the motherboard. Below where the wire is connected it should be labled on the board what fan it is.
Apr 22, 2011 | HP Compaq Fan Assembly
My cooling fan has become noisy. What do I do?
It can be fixed easily. You can opt to repair or replace it. Start with referring to the online service documents to help you locate the components and some videos.
First remove the side panel and locate the noisy fan.
If the fan on the processor is the problem, take care when removing and replacing it. Incorrect replacement may damage the board and CPU.
For all other fans, try blowing air from a vacuum cleaner with blower or a standalone blower.
If this don't fix it, use a philips screw driver to remove the fan. Disconnect the power source and proceed.
Note whether the fan removes air or sucks in. It depends on the fans direction. Remember this or take a photo.
Remove the fan cables from the mother board but remember to take a picture of wires in case you forget which goes where. Or you can just point the fan away from motherboard if the wires are long enough. CAUTION: Do not touch or remove unnecessary components. You may find it difficult to replace.
Look for a sticker on the fan (some have it on the back) and remove it, put a drop of oil in that hole and let it seep. This should be enough.
If the fan does not have a hole, use WD40 and spray it lightly underneath so it penetrates the bearing. Use a tissue paper to wipe excess. Replace the fan.
Nov 27, 2010 | Gateway 504GR PC Desktop
Gateway 504GR starts running then the monitor read "power saving"
mine does the same thing, the first time it did it, i removed the dial-up modem that it came with, and it booted up just fine with no problems. now, after a year ago of this happening it decides to do it again this morning, so i'm kind of clueless now, considering that there's no modem in it, so i have no idea what could be causing the problem
Nov 23, 2010 | Gateway 504GR PC Desktop
Power fan dosent move when turned on.
If the fan in the power supply does not move when the computer boots up, then I suggest you replace the switch mode power supply.
It is possible to replace the fan in the power supply but if you do not know what to do, I suggest you get a new switch mode power supply because this is a mains supply device and any mistakes will be lethal.
Oct 30, 2010 | Gateway 504GR PC Desktop
Gateway will not turn on.
Sounds like the power supply. Here is the part number that you can shop for online.
Bestec ATX-300-12EB3 power supply. Rev. S2
I found them on Yahoo shopping for as low as $47.39.
Hope this helps.
Feb 27, 2009 | Gateway 504GR PC Desktop
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dec 22, 2008 | Gateway 504GR PC Desktop
Fieldvision 114 mm reflector instruction manual
This scope is made in China and is the same as the Konus, my advice is find a close astronomy club and the guys there will be more then glad to help you set it up.and use it.
MAKSUTOV-CASSEGRAIN TELESCOPE
D=90MM
F=1200 MM
f/13.3
MULTI-COATED OPTICS
Aug 26, 2008 | Optics
Memory
no it does not support ddr2 ram.
goto this link for mor ingormation.
http://support.gateway.com/s/PC/R/3724/4365sp3.shtml
good luck
Jul 09, 2008 | Gateway 504GR PC Desktop
Gateway 504GR PC Desktop Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
