Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I HAVE A FLASH CODE 4 BLINKS THEN 2 BLINKS ON A
I HAVE A FLASH CODE 4 BLINKS THEN 2 BLINKS ON A GE POWERVENT GAS WATER HEATER MOD GG40T06PVJ SERIAL GELN1106517599
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Reheem powervent water heater blower runs, igniter
check the wires and make sure they are not touching any metal, or the gas valve, this is actually something I just had happen to a brand new power vent just last week the wires were touching the gas valve and shorint it out i seperated them put electric tape on each one it fired up and stayed on,,
Posted on Jun 28, 2009
  • 351 Answers
SOURCE: HAE A GE WATER HEATER MOD PE50TA. WANT TO INSTALL
Hi .. you would be better off with a double pole switch. That way all the power is disconnected from the heater when the timer turns it off.
Posted on May 03, 2010
Is the Richmond 6g40-34pf hot water heater a model with or without powervent
According to photos listed for that specific model... it is NOT power vent.
It is ordinary atmospheric gas water heater with 3" vent pipe
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 04, 2015 | Water Water Heaters
GE SMART WATER HEATER GG40T06PVJ NOT WORKING
http://waterheatertimer.org/How-to-fix-water-heater.html
Water heater brand type and model not known
Gene
Aug 16, 2014 | Water Heaters
Vacation mode hot water heater
GE is made by Rheem.
Sounds like water heater is short cycling.
Copy following link to troubleshoot by type of gas control valve, including error codes, and instructions how to replace each type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Unforturnately Rheem does not post service manuals, and refers customers to call service technicians... so wonder where these guys get service manual... or maybe they guess at it.
However 2 year old water heater is under warranty. The date of manufacture shows on poduct label serial number. 3rd and 4th digit of serial number are year of manufacture. Parts are covered in second year. Rheem might require plumber to validate single-family residential installation.
In any case other companies post service manuals that cover same gas control valves. These manuals apply to Rheem.
Only difference between Rheem/GE and other brands is type of FV system.
If the air arrestor screen gets clogged (not likely with new heater), the intake air slows down causing vent to slow down. Same amount of gas is still being released and burned, causing combustion chamber to overheat. As a result, the TRD glass vial breaks and air intake trap door springs closed. At this point the gas control valve will usually signal error flashes indicating lockout. Shutdown is usually less problematic to homeowner than allowing too much gas to accumulate inside burner at once, causing risk of explosion. Gas appliance are dangerous without doubt.
Call plumber to check everything might be safest route, especially since low gas pressure is one possible cause of short cycling. And you will be comfortable afterwards knowing who to call and that gas appliance is check out professionally not to have defects that will cause problems down the road.
May 28, 2013 | Water Heaters
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a PowerVent residential Gas Water Heater the blower runs continuously and the water is not hot enough
Copy following link for troubleshoot resources, including troubleshoot by type of gas control valve.
Brand and model number of unit is located on label side of tank.
Aug 05, 2012 | Water Heaters
Rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Feb 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
101 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
