Question about Magellan Roadmate 760 GPS Receiver
Part number 702142-02 has a loose connection where the power cord plugs in. I need that part and can't seem to find it online.The unit I have is the Magellan Roadmate 760
Have you had any luck with this problem.. I'm having the same issue.. Obviously a product defect... Please let me know, if you have any sollutions.. Futuresportinc@yahoo.com
Thanks in advance...
Posted on Feb 13, 2011
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
I have a Gateway T-6330u notebook. I have had problems with the battery cord before where it plugs into the computer. A piece broke off from the battery cord and was stuck in the computer. I talked with...
Seems more like a problem with the power receptacle where you plug the power cord into the laptop.In order to fix this problem, you will need to disassemble the unit to get access to the motherboard & replace the power receptacle with a good one.
Dec 29, 2010 | Gateway T-6330U Notebook
The plug where the power cord plugs in seems to have a loose connection. I keep losing power to the unit. any suggestions?
just try to change the ac, maybe it is the one that is defective, or if your suspicion is right open it and solder the loose contact
May 05, 2010 | Sirius Starmate ST2 Satellite Radio...
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Hello heres my problem the power cord tip gets so hot and burns even ive replaced the battery ive replaced the cord and the tip and its stil happening help please
Seems that your notebook's power socket, where you plug the power cord, is damaged & is causing a loose connection. The loose connection causes the power socket as well as the power cord's tip to overheat & burn.
Oct 30, 2009 | Compaq Presario M2000 Notebook
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
My window unit fell out of the window and hung by the power cord that was still plugged into the wall. I was able to grab the cord and pull it back up. I reattached the power cord and now every time i turn...
Its most likely is not the switch. It is most likely the cord though. Due to the excess strain on the cord it has probably cut through the rubber coating on the wire and connected to the frame and grounded the hot lead. Fix the cord and you may have it handled.
Jun 15, 2009 | Frigidaire FAX054P7A Wall/Window Air...
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
145 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
