Question about LG WM-2277HW Front Load Washer
I need to replace the bearings in my front loading washer-LG MW2277HW?
  • 343 Answers
Bearing replacement is quite a big job. The components can be replaced individually, or the rear drum assembly can be replaced as a whole. Obviously there is a difference in time involved and component cost.. Get quotes for both methods of repair and for machine replacement as well..... Good luck.....Nomess
Posted on Aug 03, 2010
Testimonial: "Nomess, thank you very much. This was very helpful and I appreciate you getting back to me promptly. Paul"
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Jul 04, 2010 | LG WM-0532HW Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Need to replace bearing in lg 2277hw washer.
I think that this might be the issue with mine also. How did you come to that conclusion on yours? I really do not know what to do at this point.
Jun 08, 2010 | LG WM-2277HW Front Load Washer
Replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Dec 02, 2008 | LG WM-1832C Front Load Washer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
LG WM2032HW Washer
You may have a bearing problem and it will need to be looked at by a qualified LG technician.  That is a big job and will require total disassembly of the tub and drum assembly to get to the bearings.  There are 2 of them.
May 06, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
374 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
