Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Icemaker does not shut off even when arm is up.
    Problem Solver:
  • 12 Answers
Arm must be disengaged inside ice maker or the smal switch in ice maker
Posted on Aug 02, 2010
  • dragonz_lair Aug 03, 2010
    So is the switch easy to find? or is in inside the housing?
  • gespinoza213 Aug 03, 2010
    the switch is inside the ice maker which can be rmoved by pulling the wire harness from ice maker and removing two screws holding the unit remove the white cover you will see where arm engages (the switch)
My BI98 u-line ice machine won't stop making ice even with bin arm up.
I would suspect the switch controlled by the tray full sensing arm/bail. That's kind of like the main power switch for the ice maker. You can remove the outer cover from the ice maker with the power unplugged! Then look at the mechanical operation of that lever as it relates to the switch. The lever should cause the switch to open and shut off the timer motor. Some times you can buy the timer separately otherwise you replace the whole icemaker. Don't forget to remove power and turn off the water before you remove the old icemaker.
Oct 15, 2014 | U-Line BI-98
The ice maker stopped making ice one day
A typical problem with these is some type of bin sensor that tells the icemaker that the bin is full. it is usually some type of "arm" that shuts it off when the ice rises to a level that raises the "arm" to "kill" the icemaker
Oct 01, 2012 | Refrigerators
Freezer is trying to make ice cubes but unable. I can hear it tripping. Should arm be in up or down position?
Hello the arm should be in the down position in order for the ice maker to try and start makeing ice cubes. when you stated you can hear it tripping what can you hear tripping can you see the icemaker arms spining. Sometimes i find it is best to remove the icemaker from the unit 2 1/4' screws located on top and one located on the bottom and then take the hole icemaker and run it under hot water for a couple minutes this causes any parts on the icemaker that are froozen up to become defrosted and sometimes it will go back into proper functioning order as well. If you have any further questions message me back Thanks
Rick
p.s if arm was in up position this would shut the icemaker off and it would not attempt to make ice any further
Jun 29, 2011 | Amana Refrigerators
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
No ice from icemaker
check see if the lever arm in the icmaker is up
Apr 05, 2009 | Refrigerators
Icemaker arm doesn't stay in the up position
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The switch on the shut off arm is defective!
Call service and they will help you replace it!
Please remember to leave a rating before you go!
Thank you
Sep 23, 2008 | Whirlpool GD2SHGX Refrigerator
Ice maker
lots of things can cause this. check the supply tube to i/m if frozen.first lift the shut-off arm up & down and listen for a clicking sound, should hear a click.
Jul 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
151 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
