Question about Whirlpool Washing Machines
2msn.comhow to install retainer spring it come off the at the bottom of boot.
    Brigadier General:
  • 3,513 Answers
Hi
Sometimes it is difficult to get the ring on front load washers; but it is much easier to remove the top, bottom and the front control panel ,then the door and support panel. Now you have the access. However this is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
http://www.youtube.com/watch?v=JvcYdj4Izlo
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
How can I change my Ram from 2 Gb to 4 Gb? Thanks in advance
It's pretty easy when you get your new DDR2 PC2-5300 RAM, just open the access panel on the bottom of your laptop. There will be several screws remove those and pop open the access. Now you should see your RAM there will be to springs retainers on each side of both your installed memory. Touch something metal to remove any static charge from yourself. Now Carefully push the retaining springs away from the RAM, it will pop up slightly. To install remember how you took the old one's out put the connector in first and slowing lay it back down towards the flat position make sure that it is seated all the way and the spring retainers snap around it to hold it in place. Power on make sure your new RAM is recognized. If your laptop detected both your new RAM sticks then reinstall your cover to the bottom. Hope this helps.
Jun 18, 2011 | HP Compaq 6715b Notebook
I need instructions on how to replace front boot seal on my neptune front load washer
Disconnect power supply to unit then remove 2 10mm screws from washer back.
Slide the top cover towards the rear to clear the screw head from flange on the bottom side of the top cover.
Pull the dispenser drawer out completely then remove five screws attaching console as shown. Roll the console down and lift it away from washer.
Open the door then expand the boot clamp spring located at the 6 o'clock position and remove the boot retaining clamp.
Pull the boot from the lip formed into the front opening then remove the four screws attaching the top of the front panel to the cabinet.
Lean the front panel forward then disconnect the wire harness to the door lock and switch assembly.
Lift the front panel off the bottom brackets and move it out of the way.
Loosen the boot clamp at the 12 o'clock position then remove the **** and the boot.
Install the new boot aligning the index tabs on it with the screws on either side of the fill tube.
Secure the boot with the clamp then reconnect the door lock and switch assembly harness and reinstall the front panel. Put the boot over the outer lip of the door opening then secure it with the boot retaining spring. Reinstall the console and the top cover in reverse order of the removal steps.
Please make sure to accept the solution should you find it helpful. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 03, 2011 | Maytag Neptune MAH9700 Front Load Washer
Tools required to change brake pads on 2003 impala
Removal & Installation
  1. Siphon 2 / 3 of the brake fluid out of the master cylinder.
  2. Mark the relationship of the wheel to the wheel stud for re-installation purposes. Remove the tire and wheel assembly.
  3. Install 2 lug nuts to secure the rotor in place when the caliper is removed.
  4. Install a large C-clamp over the top of the caliper housing and against the back of the outboard shoe. Slowly tighten the C-clamp until the caliper pistons are pushed into the caliper bore enough to slide the caliper assembly off the rotor. Use care not to tighten the C-clamp too far or the outboard shoe retaining spring will be deformed and require replacement.
  5. Remove the caliper mounting bolts and remove the brake caliper from the mounting bracket.
  6. DO NOT disconnect the brake hose from the caliper or allow the brake hose to support the weight of the caliper. Support the caliper on a piece of wire out of the way.
  7. Remove the outer brake pad from the caliper using a suitable prying tool to lift the outboard shoe retaining spring so that it will clear the caliper center lug and pull the brake pad out of the caliper.
  8. Remove the inner brake pad by unsnapping the shoe springs from the piston.
To install:
  1. Clean all parts well. If the brake pads were worn so badly that the brake rotor is damaged, it must be replaced. Light scoring of the rotor surfaces not exceeding 0.060 inch (1.5mm) in depth is not harmful to brake operation and may result from normal use. Brake rotors may be refinished. Do not use a rotor that, after refinishing, will not meet the thickness specification cast in the rotor. Always replace with a new rotor.
  2. If not done at removal, now use a C-clamp and clamp both pistons at the same time with a metal plate or wooden block across the face of both pistons. Take care not to damage the pistons or caliper boots.
    NOTE After bottoming the pistons into the caliper bore, lift the inner edge of each caliper boot next to the piston and press out any trapped air. Make sure each boot convolution is tucked back into place. Boots must lay flat.
  3. Inspect the caliper bushings for wear. Replace as necessary. Carefully inspect the slide bolts for corrosion. If corrosion if found, use new parts including the bushing assemblies when installing the caliper. Do not attempt to polish away corrosion. Lubricate caliper slide bolts with silicone grease.
  4. Install the new inner disc brake pad in the caliper by snapping the shoe retainer springs into the piston making sure both sets of locking tabs are seated in the caliper pistons. The pad must seat flat against the pistons.
  5. Install the outer pad into the caliper by snapping the outboard shoe retaining spring over the caliper center lug and into the housing slot. The pad will slide up onto the caliper and the retaining ring will lock into place on the groove in the caliper.
  6. The outer pad wear sensor should be at the trailing edge of the shoe during forward wheel rotation.
  7. Install the caliper mounting bolts and torque to 80 ft. lbs. (108 Nm).
  8. Remove the 2 nuts temporarily securing the rotor.
  9. Install the tire and wheel assembly and tighten to specification.
  10. Pump the brake pedal several times to seat the pads against the rotor.
  11. Check the brake fluid level and top off as necessary.
  12. Road test the vehicle to ensure the proper brake performance.
Good job (remember rated and comment this).
Sep 10, 2010 | 2003 Chevrolet Impala
How do i change the brake pads?
REMOVAL AND INSTALLATION
  1. Remove disc brake caliper from mounting bracket and support with a length of wire or remove sleeve bolt and rotate caliper up and out of the way to remove shoes. Do not allow caliper to hang by the brake line unsupported.
  2. Remove outboard shoe and lining. Use a suitable tool to disengage shoe springs from holes in caliper housing.
  3. Remove inboard shoe and lining, unsnapping shoe spring from piston.
  4. If installing new shoe and linings, bottom piston in caliper bore using large pliers. Take care not to damage piston or piston boot.
  5. Remove bushings from mounting bolt holes in bracket. To install:
  6. Install new bushings to mounting bolt holes in bracket. Lubricate bushings with silicone grease before installation.
  7. Install inboard shoe and lining by snapping shoe retainer spring into piston. Shoe retainer spring is already staked to the inboard shoe. Shoe must lay flat against piston.
  8. Install outboard shoe and lining by snapping shoe springs into holes in caliper housing. Wear sensor should be at the trailing edge of shoe during forward wheel rotation. Back of shoe must lay flat against caliper.
  9. Install caliper.
  10. Apply approximately 175 lbs. (778 N) of force 3 times to brake pedal to seat linings.
Aug 26, 2010 | 1994 Cadillac DeVille
How do I get that metal loop around the rubber gasket at the door? It is metal wire with a spring.
Take a flat bladed screwdriver or similar tool then insert it to where the retainer spring connects to the wire hoop at the bottom of the door seal and pull the retainer forward and then off the perimeter of the boot. You may also use a pair of needle-nose pliers to grasp and pull the assembly at the location shown below.
Reinstall the spring and wire hoop assembly by starting at the top then working simultaneously around on both sides going to the bottom of the door seal
Aug 18, 2010 | Kenmore Elite 45986 Front Load Washer
How do you install rear struts on a 97 dodge avenger
you will need to set the car on jack stands, then remove the tires, then remove the bottom strut mount bolts, pop the trunk, and the top mount bolts should be easily accessible remove them also, then you will need strut spring compressors, compress spring, remove top retaining nut, then remove old strut install new strut tighten retaining nut release springs and install back on vehicle.
Mar 15, 2010 | 1997 Dodge Avenger
I have a Samsung front load washer model # WF317AAG with a torn gasket. I have the new gasket, but I do not know how to install it, can you provide install instructions?
to properly install this you nee to remove the retaining spring on the front of the boot.
then remove the lid.
next remove the four screws that hold the control panel in place.
then remove the four screws that hold the fron panel in place ther may also be two screws on the bottom of the front panel.
once you remove the front panel you need to set it aside but the door lock switch is still attached so be carefull.
one you remove the front panel you can get to the other retaing spring and remove the boot.it is easier for me to also remove the counter weights on the front of the tub.to put the boot back on.i hope this helps would like to here more on your progress
Feb 02, 2010 | Samsung WF317AAG Front Load Washer / Dryer
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
Door Lock/Switch Replacement Procedure
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On a 1989 nissan maxima with sonar suspension II how do you disassemble the strut assembly? the mounting bracket for sonar adapters is in the way of the strut center bolt.
First you must remove the rear seat to gain access to the top strut mounts. The bottom of the rear seat comes out first. On the 91 model there are two tabs at the base of the seat bottm that you pull forward to release the seat bottom. I'm not sure if the 89 is the same. After removal of the rear seat bottom, you will see a bolt at the bottom of each side of the rear seat back that need to be removed. Fold down the arm rest and disconnect the vinyl cover at the base of the armrest to expose and remove two screws. Push up on the rear seat back to unhook three plastic hooks (center and one at each end) at the top of the rear seat back. Remove the seat back. Remove the large metal support panel that is behind the seat back. Safely jack up the rear of the car and support on jack stands so the rear wheels hang free. Doing one strut at a time, remove the two top strut mount bolts leaving the center strut stud nut in place. The strut and mount will lower out of the unibody. Disconnect the bottom strut mount. Remove the strut/coil spring assembly. Using a strut/spring compressor (some auto parts stores rent these) compress the spring. Carefully remove the top strut stud retaining nut, top strut mount, bumpers and strut boot. Carefully install compressed spring, strut boot, bumpers and top strut mount on new strut and install washer and retaining nut. Reinstall strut and etc. in reverse order.
Sep 15, 2009 | 1989 Nissan Maxima
Wire came out that goes around rubber part to front loadingwasher
It sounds like the door boot has come off. The "wire" sounds like it's the wire hoop retainer that holds the boot onto the cabinet.
If this is the case, check to make sure the retainer is all in one piece. If it is, great. If not you will have to replace it.
To put it back on with one person:
1) Find a small flat head that will fit into the small loop (where the small spring that streatches the retainer). If you don't have a flat head, a torx 10/15 screwdriver will fit in there perfect.
2) Rotate the retainer so the spring is at the bottom.
3) Put the top part on in the grove (at 12 o'clock)
4) Stretch the spring while you are feeding the remainder of the retainer in the grove.
This can be difficult to do alone, and if you are unable to do it alone, you will have to use the 3 handed method:
1) Place retainer in grove in the 12 o'clock position.
2) Get another person to help you out, and hold it in place while you stretch the spring and feed the remainder of the retainer in the grove.
Feb 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
