Question about Samsung Refrigerators
Samsun fridge - strange noise
I have a Samsung refridgerator marked RL38EBMS which is making a sound like an old lightig plant and the digital display output is reading "rd".
If I switch off and then on again, it runs for a moment, starts it's rough running sound and then shuts down into this "rd" mode.
I put my ear to the back panel and the noise is emmitting from about 30cms above the motor and electrics opening at the back.
Many thanks,
Steve
SOURCE: Noise from Deodorizer
Your defrost sensor is not working and is allowing a large build up of ice in the fan compartment situated behind the interior back panel (low down) in the fridge compartment. What you hear when you open the door is the fan slowing down (the fan is switched off because you opened the door) and the blades are striking the ice build up making a scraping noise which stops when the fan stops. Removing the inner panels (two, top & bottom) will allow you to get in to the fan area & then defrost manually. ( I use a wallpaper steamer which takes about five minutes to get rid of the ice) Note the topmost inner panel has a couple of electrical connectors to the interior lights which you must disconnect before you can remove the panel. The final solution is to replace the defrost sensor then sell it quick and buy a better designed fridge freezer!! VeloFellow
Posted on May 03, 2007
bobotfel
  • 236 Answers
SOURCE: GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Posted on Jan 09, 2008
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
SOURCE: Loud humming noise as fridge is running
My hot point freezer fan was making a variable hollowing sound as well. I talked to a repair guy and he mentioned that the bushings seem to wear out on the fan motor located under the ice maker. I ordered a new motor $82.70 and replaced it myself. Took about an hour to replace and it fixed the problem.
Posted on May 16, 2008
TheMazz
  • 78 Answers
SOURCE: Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Posted on Oct 28, 2009
24raq-3 makes a bubbling sound when not in use. This is actually from the AC unit inside the house. It is a wall unit.
An older fridge can make some strange noises. Mine sounds like wind blowing across a chimney.
A friend also complained his fridge sometimes sounded as though it was boiling. Someone told him to turn it upside down for a time and then right way up four 4 hours before switching on again.
He rang me thinking the guy was crazy but I told him I had heard something similar many years ago and in fact I had actually followed the instructions I was given and turned the fridge end-over-end a few times and restored it to health. My friend also seems to think his fridge sounds better...
Oct 02, 2017 | Refrigerators
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Samsung side by side refridgerator making noise and freezing
Feb 12, 2008 | Refrigerators
Refrigerators Logo
135 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
