Question about Panasonic Office Equipment & Supplies
I have a panafax 8000. It is giving me a J01 error code which is the front door. There is no paper misfeed. It does make an awful squeaking noise also. It just started happening out of nowhere. The fax for us is business critical and I am about to rip my hair out.
  • Anonymous Nov 17, 2008
    same problem
Logjam
  • 159 Answers
SOURCE: Panafax UF-885
paper jam error codes rely on input from sensors in the paper path. On this machine there is 1 sensor that is triggered by a mechanical actuator on the cartridge. Actually, the cartridge is generic, except for the position of this actuator. It is part of the guard that prevents damage to the drum, when it is removed from the machine. The positon of the actuator is different in the case of 4 different manufacturers who use this engine. Now, the effect of this actuator is to tell the machine that a cartridge is actually present in the machine. Now, some cartridge re manufacturers have removed this actuator entirely and technicians will jam the sensor in the machine with gum or a piece of paper to allow the use of this generic cartidge. Unfortunately, the paper path becomes obstructed, not with paper, but by the media that the technician has used to de activate the sensor. Look for this and replace the media with something more robust that will not become dislodged.
Posted on May 27, 2008
gbsoffice
  • 55 Answers
SOURCE: Panafax UF 895 problem with
your code 030 is a misfeed, here is a link for the manual
http://www.businessneedz.com/Manuals/Panasonic-Panafax-UF-890-Owners-Manual.pdf
Good Luck
Posted on Feb 03, 2009
FixinFax
  • 3085 Answers
SOURCE: J01 error, but no paper jam; can't re-set
Remove the toner cartridge.
There should be 2 switch actuators sticking up from the base.
It sounds like one of these actuators has been knocked loose. Try to clip the actuator back on to the sensor.
This is a TOUGH job, you may need a sercive tech to look at it.
Posted on Oct 13, 2009
  • 6 Answers
SOURCE: how do you flush the panafax 8000 memory?
Your killing a fly with a sledge hammer. If you do a ALL JOB clear from test mode 6 instead of SHIPMENT SET... you wont loose all your one-touches or fax parameter settings.
Posted on Nov 03, 2009
  • 127 Answers
SOURCE: Regarding my Panafax UF-8000: Why does evrey page
clean the rubber feed roller/rollers that actually feed the paper from the paper tray.. clean soft lint free cloth dampened with water
Posted on Mar 31, 2010
Testimonial: "Thank you! That seemed to do the trick! I'll monitor it for awhile--perhaps the big roller should be replaced soon. Greatest fax/scanner!"
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Regarding my Panafax UF-8000: Why does evrey page misfeed? I started with 24lb white paper and switched to 20lb, but still it is misfeeding.
Mar 31, 2010 | Panasonic PanaFax UF-8000 Laser Fax
REMOVE PAPER MISFEED
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe you knocked one off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I am having an issue with a Panafax uf-8000 printer. It grinds when starting up and says there is misfed paper. Don't see any.
Paper feeder sensor guide is open or displace ,So it said misfed paper.Clean sensor or right position set the sensor guide.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Message; remove misfeed paper, when its not misfeed paper at all
One of the feed switch actuators is trapped down. Remove the toner cart and check underneath.
Open the rear door and check there too.
Nov 12, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Oct 13, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Paper struck
Fusing rollers are not turning, Grease the bushings / bearings.
Perform Shipment Set.
May 27, 2008 | Panasonic PanaFax UF-8000 Laser Fax
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
81 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
