SOURCE: 6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
SOURCE: Help with Craftman 5.o snowblower model @ 536885211
Turn on gas with the carb bowl off and float hanging and see how much fuel flows.It should be a steady stream.Have seen the seat in the needle and seat swell that only lets gas drip through not enough to keep it running.
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
SOURCE: Mower will not stay running unless primer button
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
