Question about Dryers
No heat in dryer it is elec have replaced element
    Genius:
  • 1,073 Answers
Check the safety stats also check the voltage going to the dryer
Posted on Apr 25, 2008
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
jsrock516
  • 5911 Answers
SOURCE: replaced element and dryer still won't heat
You replaced the heating element, but did you check the Thermal Cut-Out (TCO) or Hi Limit Thermostat? These two components work in conjunction to regulate the temperature of the heating circuits. In most dryer related heat problems, the TCO will fail before the heating element.
The TCO is located on the outside of the heater box at the end opposite the heating element leads. The Hi-Limit Thermostat is also located on the outside of the heater box, but is located adjacent to the heating element leads. Both these components should read 0 ohms with a multimeter if good. If either component is found to be defective, you must replace BOTH of them at the same time. Failure to do so may result in premature failure of any components you replace. Thats why these two parts are usually sold as a set. The part number is 279816 and can be purchased at any of the following websites:
searspartsdirect.om
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
You can view a diagram of these components using the helpful exploded view diagrams on the any of the first three websites I have listed. The last website only shows part illustrations. The TCO and High Limit Thermostat will be listed as items 6 and 15 respectively under the "Bulkhead' parts section. NOTE: Item 6 comes with item 15 when ordering.
Another thing to consider is the input voltage at the wall receptacle. Did you verify the voltage was correct? You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
Now if you determine the TCO is defective, it usually blows for a reason. It usually fails due to an overheat condition. This is commonly caused by clogged or poorly installed exhaust vent ducting. If you haven't inspected or cleaned the dryer interior, or external ducting recently, now would be a good time to do so before you replace any parts. If left in a poorly ventilated condition, a dryer will overheat to the point of failure. Which may potentially ruin any new parts you replace.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Oct 09, 2009
  • 24 Answers
SOURCE: replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
Posted on May 25, 2010
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
No heat
Your problem is more than likely one of the following:
* heat source: elec. heat element, gas coils, gas igniter or radiant sensor (depending on elec. or gas model)
* thermostat
* timer
Feb 19, 2010 | Amana ALE866SB Electric Dryer
I have a kenmore elite dryer for about 4 years and it will not heat up. Can you please help?
check breakers in panel make sure both are in the on possition(home elec. panel)....if thats not it replace both heating elements...they are located on the back usually held in by 2 screws in each one..youll find these at lowes or home depot
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Hello there:
I would have to tell you that i dont think that the two would fail at the same time but it can happen but not too often
deffinatly replacethe timer and the heating element and this will solve the problem
also since you have the unit opened i would inspect all of the wiring for loose connections and moisture cause this will cause things like these to fail prematuraly ok?
I hope that this has peeb very helpfull for you
best regards michael
Nov 04, 2009 | Kenmore 659 Electric Dryer
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
My Maytag elec dryer does not heat. It is a
You have to use a multimeter to test the heating element for continuity and if that is good, you have to test the other sensors. A wiring schematic is included with your unit, someplace on or in the unit.
May 09, 2009 | Maytag Dryers
How do i replace heating elecment in my whirlpool gas dryer
a gas dryer does not have a heating element
Apr 13, 2009 | Dryers
KitchenAid elec. dryer not heating
check and make sure your breaker isnt part way flipped .... dryer will run on 110v but wont heat unless it gets 220v ,,,, break may look to be on but not ,,, turn off breaker, wait 30 sec and flip back on hard / larryyb
Dec 05, 2008 | Dryers
Dryers Logo
46 people viewed this question
Top Dryers Experts
