Question about Meade 8 2000mm f/10 LX90 LNT Motorized Schmidt-Cassegrain Astro Telescope, UHTC Coatings, with 497...
I tried powering up my Meade LX2000 8" the other nignt but I couldn't. I was using a battery jumper for power and thought that maybe it wasn't fully charge so I swithed to battery power and still couldn't get it to power up. Thanks in advance
  • 3,186 Answers
First thing to check or replace is the hand controller cable.
Does the red light come on -- on the control panel. If yes the scope is receiving power but it's not going to the hand controller. I have had two Meade cables fail. A longer one is available on
www.scopestuff.com here:
http://scopestuff.com/ss_lxdec.htm
However these scopes do have an issue with blowing out the capacitors on the power circuit board. To repair the scope must be returned to Meade, or you need to find a local electronic repair technician and be willing to remove the board yourself and take it to them.
Try the new cable first-- before you panic.
Posted on Aug 02, 2010
Testimonial: "Thanks for your quick response. Unfortunately the light doesn?t come on so I guess I?ll have to send it in."
  • Joe Lalumia aka TelescopeMan
    Yes, time to send it back for repair. By the way, never plug or unplug cables while the scope is turned on. This is what causes most blown out circuit boards.
Battery keeps dying on my 2009 honda civic dx
you have a short somewhere in the vehicle try turning everything off and ignition fully off disconnect battery and then as you reconnect see what sort of spark you get if it's quite large there is still something drawing power put a meter between the terminal and cable to see what power its drawing if it's low try turning things on one at a time untill you get a surge that will point you in the right direction to the item thats drawing most power
Apr 10, 2014 | Easy Quick Auto Jumper Recharges Vehicle...
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
There is no power in my PC. i change the power supply but still there is no power coming out. It looks like its all dead. I thought it is the power supply but it wasn't. Now my thinking maybe it is...
Disconnect everything from the mother board except the power supply. ie no ram, drives and any front panel cables including any sound/headphone jack sockets. All you should now have is the processor and vga to a monitor. If when shorting the power on terminals nothing still happens, remove the battery and wait 5 mins. Short the rtc jumper and see if it will start now. If nothing then motherboard is scrap.
Aug 14, 2011 | ASUS P5KPL-AM SE Motherboard
My LX200gps 10 inch microfocuser has quit. Earlier my power button was intermittent, now it works. The handcontroller alllows you to slew, but not focus. I used spray contact cleaner in the power and...
When you plug in an outside power source the internal batteries are disconnected- automatically. First thing I would try is all new cables Sounds like the motor inside the focuser died.
Apr 12, 2011 | Meade LX200GPS Telescope
We have a Peg Perego John Deere Buck 4-wheeler that will no go. I thought maybe the battery was bad so I replaced it with a fully charged new one and it moved about 300 feet and then wouldn't do anything...
try jumpering the battery directly to the motors to see if the motors spin, if they don't then replace the motors as needed, if they do spin, then use a multimeter and check for 12 volts at the motor wires when the accelerator is pressed, if its showing no volts then work your way back to the shifter switch and check for volts, then to the foot pedal to find where the power isn't getting through then replace components as needed
Jul 08, 2017 | Peg Perego Toys
I have six Meade ETS-LX 6" telescopes which are used in an introductory astronomy lab. I have upgraded the firmware and other files in three of the six and they are working fine. The other three do...
These scopes have many bugs in the firmware and are not a mature technology. Some people have issues and some do not.
About the only thing you can try is to reload the firmware using the SC CARD method. Contact Meade or read the manual to learn how to upgrade the firmware using an SD flash memory card.
Other than that the scopes will need to be returned to Meade for repair.
Mar 07, 2011 | Meade DS-2130 (350 x 127mm) Telescope
I just bought a used ETX125 PE the motor that lifts the scope seems to power out,or simple cannot swing up!
Are you using the internal batteries? Are they fresh and fully charged?
Replace them and try again; or better get a seperate 12 volt power pack and the correct Meade 12 volt cigarette lighter style power cable.
Feb 27, 2011 | Meade ETX-125PE (500 x 127mm) Telescope
Set up my meade lx200 gpx two nights ago and I used my power tank , no power! Ithen put batteries in the forks, still no power. can you help me? cford@cut.net
Is the control panel red light ON? If not you have a power circuit board problem.
Meade will want the scope returned for repairs.
http://www.meade.com/support/index.html
Oct 04, 2010 | Meade LX200GPS Telescope
I have a meade 4501 telescope. It has an
See if a manual is listed on the Meade site Here:
http://www.meade.com/manuals/index.html
That shows the power supply voltage.
Jul 12, 2009 | Meade Optics
No power output from my vector 1000w inverter.
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
Meade 8 2000mm f/10 LX90 LNT Motorized Schmidt-Cassegrain Astro Telescope, UHTC Coatings, with 497... Logo
226 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
