Question about Game Elements HV-5 (GGE904) Wheel And Pedals Set
Looking for an electric element for a patio heater, the make is fire mountain the model number is zhq1821sh, can you help
  • lorriane_ell Aug 03, 2010
    looking for a rerpalcement halagon bulb for patio heater. not a new heater. fire mountain zhq182ish
  • 787 Answers
Hello.
Unfortunately, there are no parts available for purchase.
Posted on Aug 03, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links for your help…
http://www.leisureheating.co.uk/shop/home.php
http://hubpages.com/hub/Electric-Patio-Heaters
http://www.amazon.co.uk/Fire-Mountain-Electric-Standing-Heater/dp/B000Y14TDE
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
Need to install the Zhq1821sh heater, so i need the manual
You need the name brand plus the model and then I could possible help you
Jan 07, 2013 | Water Heaters
Frontgate patio heater, serial number 01A02 0023562, model number SRPH02, cust number SHCDPH, pilot light won't light (checked gas tank already)
First check that you are getting a spark, if not check lead and ignitor. If getting a spark make sure that there are no leaks, to do a gas leakage test see Patio heater problem solving. Next check the tilt switch if fitted, just short it out by joining up the two leads. If OK look for any debris/insects around the pilot and clean. A worn thermocouple will turn the gas off, these can last anywhere for 2 years up to 6 years but will at some point need replacing.
May 18, 2011 | Frontgate Stainless-Steel Outdoor Patio...
I have a zeus patio heater. the right side element wont come on, but when i put the element in the left side it is fine. Can anyone help?
The burner is either clogged or rusted out on the side that doesn't come ON. You will need to replace the entire burner though, to solve the problem.
Hope this helped you.
Apr 25, 2011 | Superb PHP40 Patio Heater
Where are the heating elements on an 80 gallon electric water heater? Model number : E 2 F8 0 H D 0 4 5 V
I don't know that model number.
Tank-type water heater elements are located behind panels on side of tank.
Open following link to help troubleshoot electric water heater problems:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
The water heater label also shows element wattage, brand, voltage, serial number, and type of operation.
For example 5500W elements, non-simultaneous, 240V are typical ratings found on water heater.
5500 Watt would be replacement element size.
Non-simultaneous would indicate that both upper and lower element are not turned ON at same time.
240Volt is typical voltage for water heaters.
Serial number carries date-of-manufacture, based on brand.
For common brands:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 13, 2011 | Whirlpool Water Heaters
What mantles do I use for a coleman patio heater/lamp??
You didn't list a Model Number for your Patio Heater, so it's hard to say, which one you need.
However, you can contact Coleman direct at 800-835-3278 give them the Model Number and you can order one directly from them.
Mar 09, 2011 | Coleman (5040B750) Patio Heater
No hot water
We are always ready to help you do it yourself.
If you have electric tank-type water heater, do a troubleshoot outlined in next link:
If you have tankless, or tank-type gas, or atwood RV heater, or indirect boiler fed, condensing, heat pump, hybrid, high efficiency gas or electric, oil fired, point-of-use, solar assisted, or other type of heater, please add a comment with brand and model number, and detailed description of what you know and have tried so far.
I may not be able to help with other types of heaters.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Mar 02, 2011 | Element 2000W 8" WATER HEATER ELEMENT
Patio heater lights but will not stay on
When posting on here to get help, it is always good to list what you are working on, who manufactured it, and what model it is. otherwise we have no idea most of the time how we can help.
If I can assume that you are working with a propane patio heater that ignites and then goes out , maybe I can help.
If it is firing up, then going out right away it is the thermocoupling inside. without knowing the make or model i cant tell you what the part number is. these are very common parts that can be aquired by calling the manufacturer and telling them what you need. they will either sell it to you, or direct you to somebody that can
Nov 15, 2010 | Pool & Spa
My Kenmore Gas Range (Model Number 318112101) Can start a fire above, but the moment I try to bake something, the electric heaters at the bottom refuse to turn on. Whats wrong with it?
i need the first three numbers on the model number,it says it's a gas range but you say it has electric heaters in it,if it's gas most likely it will be the ignitor,if it's electric then it will be the element,send full model number and i can help you better
Oct 31, 2010 | Kenmore Kitchen Ranges
Charmflow patio heater will not fire
turn the knob on very slowly just enough to fire up the heater. once it is fired up slowly adjust it.
Apr 24, 2009 | Brinkmann Charmglow 810-7400-S Propane...
Game Elements HV-5 (GGE904) Wheel And Pedals Set Logo
Top Game Elements Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Game Elements Video Game Console and Game Expert? Answer questions, earn points and help others
