Question about HP Photosmart C6180 All-In-One InkJet Printer
Just replaced the ink cartridges. Printer keeps telling me to turn it off then on. However, it fails every time I turn it on again.
  • HP Master
  • 5,523 Answers
With the power cord connected and the unit on, disconnect your data cable(s) from the printer (USB, parallel). Press the power button to turn off the unit; wait 15 seconds and then turn the power on again.
Check if the error comes back. If it doesn't, reconnect your data cable(s) one at a time, checking for the error message between adding each connection. If you see the error, replace that cable.
If the error did come back after cycling the power when no data cables were connected, you have to look at your power cable. If the cable has a power module (box that you plug another cord into), make sure that you have the correct one for the printer.
In either case, unplug the power cord from the back of the printer (first) and unplug it from any surge protector or power strip (second). If you have a power module, unplug the cord from that and reconnect. Wait 30 seconds. Plug the cord directly into the wall outlet and then into the back of the printer. Then turn on the printer.
Check for issues. If the printer turns on, you may have overloaded the power strip. If it doesn't turn on, you should check the outlet for problems. Try using an outlet in a different room (preferably a different circuit breaker). (Move the printer and its power cord.) If the printer still doesn't work, replace the power cord or module.
If none of the above works, the printer needs service.
I hope this helps.
Posted on Aug 02, 2010
Ink light on changed ink still wont print
it sounds like the printer has not accepted the changed cartridge.
Try turning the printer off at the mains for 30 seconds then back on again, it sometimes works, or if that fails take out the cartridge's turn off printer for 30 mins then back on re insert inks and see if that works.
If it fails then there could well be a chip set failure on the cartridge you have replaced or maybe another cartridge within the set.
It's well worth saving the cartridge too as compatibles sometimes fail to be read by your printer but rarely the actual cartridges fail, you can put that same cartridge back in later for it to be accepted by the printer.
Jan 15, 2014 | Epson Stylus Photo R260 InkJet Printer
My MX 700 won't print. I replaced thje yellow and magenta cartridges an dit keeps telling me that the yellow still needs to be replaced
Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place. reseat it again then turn off the power then restarts most of the time this fix the issue
Dec 02, 2013 | Canon PIXMA MX700 All-In-One InkJet...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
My canon printer multipass mp370 say put in cartidage and say's regitration failed
The cartridges are empty and must be replaced with new ones - models BC-24b for black ink and BC-24c for the colored ink. You can buy them at your local pc or printer shop.
This must be done with the printer and the pc on - once the new cartridges are in a popup window will appear on the screen asking you which cartridges were replaced; tell them both and the Registration failed error message should be gone - check that from the Maintenance > Ink counter reset option.
If it's not then maybe the driver and the associated software is corrupted and it will have to be reinstalled.
If even that fails then the memory chip responsible with keeping theink levels is faulty - this is unfixable, the printer is dead. Sorry, time for a new one.
Sep 11, 2011 | Office Equipment & Supplies
Every time I try to print or scan it always tells me to remove the ink cartridges and replace them and after I do it tells me that I need to turn it off and on again then the light blinks orange
Hi,try looking for any paper sensor that might have stuck in its place.
wow that machines a fossil now! :P it sounds like you've purchased dud cartridges. the check the dates on the new cartridges, they might b expired. then clean the copper plates on the cartridges with a tissue and a small drop of windex of method, and then where they match up in the printer. sometimes ink can get on the electrics and they don't connect properly with your printer. if all else fails, just take them back and tell the people where u bought them from that they don't work and they should replace them.
Hope it helps.
Thanks for using fixya...
Dec 01, 2010 | HP Photosmart C6380 All-In-One InkJet...
I just replaced all the ink cartridges and the message says ink system has failed turn the power off then on again,. i have tried several times and get nothing
Hi Please follow the the steps given below Make sure that the printer's power cord is connected to the walljack (Avoid if there is any surge protector or extension cord) Take out all the ink cartridges Take a clean cloth, dampen it in distilled water and with that cloth clean copper contacts of the cartridges firmly Let them dry for 2 minutes Unplug all the cables from the back of the printer while printer is turned on (After closing all the doors that are open and also keep the cartridges out) After 2 minutes, plug in the power cable Put the ink cartridges in one by one, then close all the doors again Printer would start going through some maintence and then would start aligning the ink cartridges All the best!! Regards
Oct 27, 2010 | HP C6280 All-in-One Printer
Printer screen reads "ink system has failed. unable to print. refer to printer documentation. error: 0xc18a0301. turn power off and then on again." i have tried turning it off and on repeatedly and every...
jusr solved this off an article. the *,#,123 thing only gets you a r0046 support answer no sytem configuration menu, so.........hit cancel the hold down canel, ok black and color buttons at teh same time, error message continues, keep holding all 4 and the power off with on botton, let sit for a few seconds, my have to restart a few times but maintenaince is done and volla-fit it. up your hp-let keep em honest. andy fecteau
Aug 26, 2010 | Office Equipment & Supplies
Repaced ink cartridges,
I think it is not recognizing the new cartridges. Try to clean the slots of the cartridges where you place them. Try to clean cartridges bottom.
Than go to windows open the software installation CD provided and recalibrate the printer and there could be one more option to try.
If my advice helps you out rate me.
Thanks
Mar 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Feb 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
