Question about Delfield Freezer 6151XLSR Stainless steel
How do I replace the door gaskets on a Delfield Model 6051 refrigerator? I can't see how to get the plastic inner panel off to release the gaskets and there is no help in the operating manual.
  • Delfield Master
  • 1,262 Answers
From what their web site shows, all of their gaskets are some sort of push in (Dart type) or clip in on a strip. Removing the inner panel is not necessary.
http://www.delfield.com/docs/uploaded/del/Parts/dpc08.pdf
go to page 36 and it shows the construction of the their gaskets.
Posted on Oct 16, 2010
I wish to remove the Door. How do I disconnect the wiring Harness from door to freezer?
unplug from the outlet before this,,open the door,unscrew from behind the door seal,take off the plastic inside door,then unplug everything and then unbolt the hinges
Apr 29, 2015 | Freezers
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
Need to know what suction pressure and head pressure should be to have a-20 degree evap. model 6151S Delfield Freezer
Head pressure = ambient + 25*F convert to pressure, look at P/T chart for type of refrigerant.
Feb 02, 2011 | Delfield Freezer 6125XL-S
Need seal for center door for comercial 3 door Delfield.
A good parts store will carry ready made gaskets, just bring a sample to match.
Apr 28, 2010 | Freezers
There is water leaking out of the front of the unit
Got to be bad gaskets. Get a new gasket from partstown dude.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 12, 2009 | Delfield Freezer Series 6000XL Remote Half...
Need a service manual for a 6176 series three door freezer. do u know where we can find one?
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
If I understand the model number, I believe your unit is a Delfield. Go to this web site for Archive Manuals for Delfield.
Hope this help.s
Oct 27, 2009 | Freezers
Delfield freezer 6151-S ,replaced door gaskets and they don`t seal
Take a hair dryer (or take off the gasket and throw them in the clothes dryer (yes I am for real I do this all day long)) then put them back on. or the hair dyer way is keep heating the gasket up and holding the door closed while you do it. they should start to seal as you are pressing them together.
Sep 23, 2009 | Delfield Freezer 6151XLSR Stainless steel
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Delfield Freezer 6151XLSR Stainless steel Logo
184 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
