My hotpoint wm64 is making a lot of noise on spin
  • HelpmyWM64 Jun 05, 2008
    I also have the same problem, a kind of grinding / rattling noise on fast spin, does not happen when machine is empty, bearings changed last year, checked springs on top of machine and these are ok.
  • jue1966 Oct 09, 2008
    I have the same problem - loud noise on spinning and draining - ultimately unable to find any solutions online so called repair man out today - will update with his verdict
Can someone help me please, I have a Hotpoint WM 64 from last week it gives prob. Works well but when you choose a prog it starts well but during last half (as it reaches the green line which i think it means rinse) it stops then i have to kind of go for an other wash to get the cloths rinse well. Anyone have any idea what is going wrong with the machine..?
Posted on Sep 24, 2008
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Hi.
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Regards.
Ginko
Sep 13, 2011 | Hotpoint Washing Machines
Hotpoint Aquarius WMA 52P - My machine makes a lot of noise on the spin cycle. Any ideas?
definatly the drum bearing its common with those washers some repair men will do it for £80 thankyou
Jan 13, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint wm64 does not spin dry
Remove the top cover of washer and check the brushes in the motor, replace them if less than 3-5 mill left.
If brushes o/k then make sure belt is on, and make sure it is draining o/k.
Aug 16, 2010 | Washing Machines
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Very noisey on spin cycle
Almost certainly the main drum bearings have failed.
Jun 25, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WM64 keeps fusing and cutting out
it's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
Mar 12, 2009 | Hotpoint WMA64 Front Load Washer
WMA22- Machine has started making lot of noise.
Sounds lika main drum bearing problem
As it is only 6 months old, then you should contact service agent.as it will still be under guarantee.
Aug 02, 2008 | Hotpoint First Edition WMA22 Front Load...
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
