Question about Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor
Trying to find a manual with a caberator parts break down for TH2448
    Problem Solver:
  • 11 Answers
You can usually find a parts list with a break down on the manufacturer's website. They usually have online parts and manuals that you can open in a PDF file.
Posted on Aug 02, 2010
Where is the airscrew on the caberator?
It will be in the carb base plate that contains the throttle valve.
Sep 13, 2016 | 1994 Fiat Uno
Yz 85 2005
Did the bike sit for a long while with gas in it?
What happens over time is the gas starts to break down (go bad).
When it does this, it turns into almost a varnish.
This starts plugging the holes in the jets, and the ports drilled in the carb, starting with the smallest, which is the idle circuit.
What is happening in your case is when you spray carb cleaner down the carb, it starts and runs on that, until it's used up.
You need to remove the carb and "boil it out" (clean and rebuild), paying attention to the idle jets and ports.
This diagram of the carb might help you:
http://www.bikebandit.com/houseofmotorcycles/2005-yamaha-yz85-yz85t-carburetor/o/m145327sch299511
Again, pay attention to the idle jet (pilot jet), #8 in the diagram, inside the float bowl.
Feb 17, 2014 | Motorcycles
Owners manual/ caberator diagram
parts tree.com will help if not try SearsPartsDirect.com
Sep 08, 2013 | Tecumseh Enduro Vertical Engine 16 HP 1in...
The parts diagram with the manual does not show the part in the break down. It's right in the center of the trans and when you push forward on the drive pedal you can see the broken piece.
http://generaltransmissions.com/en/technology/ They are the MFG of the transmission. you can call them for parts. Best Joe 1_31_2014_3_13_52_pm.png
Jul 11, 2013 | Garden
I start it up and it runs then stops runs after less then 1min i have check the petrol thats all fine so what can it be thanks josh
Hi, My guess it needs a caberator cleaning, The jets are clogged or partly clogged. Also replace the sparkplug of same kind. Good luck.
Jul 13, 2011 | 2008 Cpi Aragon 50 GP Paddock
Have a coleman powermate 5000 gen. starts fine then dies like it is running out of gas. new fuel and filter is good. getting good gas flow.
Sounds like you may have a stuck float. It is inside a cup that hangs down under the carburator, there should be a nut and a serrated screw adjustment value. Put a empty coffee can under it to catch the gas and remove the nut the cup will fall off into your hand, you will see the float make sure it moves up and down on it's own weight. Sometimes they get old and stick it is held in place by a small pin (don't loose the pin) unscrew the adjustment pin counting how many turns it tales to remove, clean every thing with carberator cleaner, you may have to buy a new gasket for the top of the cup, they are very thin and break easily. Reseat the gasket in the groove it came out of, put the cup back in place and put the nut back on just an-off to make it good and snug, screw the value pin back in place counting the turns so it sits were it was before. Make sure the gas value is open and try to start the engine, at first it will fill the cup with gas then it should start up. If not you may have to disasseble the caberator and clean all the tine little ports, I have one that was so bad I just had to replace the caberator.
Apr 18, 2011 | Coleman Powermate Powermate 5000W...
When I go to a high pressure nozzel engine quits when I let go of the wand trigger. Found O-Ring on caberator bowl dammaged.
PRESSURE CONTROL WOUND DOWN TOO FAR CAUSING IT TO SPIKE....WHEN YUO RELEASE TRIGGER CAUSING OVER LOAD ON MOTOR WHICH STALLS.BACK OFF THE PRESSURE CONTROL(THE VALVE THE PRESSURE HOSE SCREWS ONTO)IT MAY TAKE AFEW TRIES TO GET IT RIGHT,YOU WILL SEE THE NEEDLE ON GAUGE JUMP RIGHT AROUNDJUST AS YOU RELEASE THE TRIGGER,THAT IS WHEN IT STALLS TURN ADJUSTER 2 MAYBE 3 TURNS ANTICLOCKWISE TO START WITH GO UP OR DOWN FROM THERE WATCH THE NEEDLE ON GAUGE IT SHOULDNT BOUNCE(SPIKE) ON RELEASING TRIGGER
Jul 30, 2009 | Garden
1993 suzuki swift automatic keeps cutting out
suzuki swift normally comes with two gas filters one underneath the bonet and one at the back underneath that one at the back might be clogged up or even the one in the bonet
Feb 05, 2009 | 1993 Suzuki Swift
Miela cv 615 water tank leaking and parts manual
Where were you trying to download the parts manual from?
You can open the front door and remove the panel but I would recommend getting a trained technician to do this. Having been through a big repair process on my CVA610, I can assure you that any money spent will be worth it by saving you a lot of hassle. These are complicated devices.
Apr 22, 2008 | Miele CVA615 Espresso Machine
Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor Logo
60 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
