Cannot access tv with remote - Televison & Video
    President:
  • 1,099 Answers
The problem might be from the remote control,
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again
Posted on Aug 02, 2010
I need codes for universal remote for access hd tv
Can I use a universal remote and if so which one and what is the code for access hd dta1030 converter
Oct 29, 2011 | Access Hd Access Hd 1080d Ntiaapproved...
I have a panasonic PV-M2768 and i don't have the original remote. I have a RCA universal RCR312W. I have tried all codes I can find. (interesting side note: the remote manual says to enter a 4 digit...
Universal remotes are a very limited devices for a replacement of a remote.U get the tv for power on/off,channel up/down and volume up/down,the basic that all u will ever get it out of the universal remote.No button said Menu on the front of the tv for acessing tv Menu,than sorry no combination of buttons,will help u to access the tv Menu.Sorry,but now,u must buy the tv original remote.Try website like Remotes.com to buy an original remote.
Mar 03, 2011 | Panasonic PV-M2059 Combo
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
I HAVE A MEMOREX TV HOW CAN IGET THE SAP OFF MY TV WITHOUT A REMOTE
Access the menu options by pressing the buttons on the TV or get you a cheap RCA or GE universal remote.  Program the thing using the access codes provided and then turn the sap off using the remote.
Oct 29, 2009 | Memorex MT201224 20" TV
Rolling picture Philips Matchline 32pw9523/25
I don't have the TV remote i bought a phillips univesal remote control but i can't access the set-up menu.
Feb 03, 2008 | Televison & Video
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
