Hello The tv is about 2 years old and for a few month ago a red vertical line apeard on the screen going all the way from the top to the bottum of the schreen. Sometimes I could make it disappear by turning it off for a few seconds. But now there is 2-3 red vertical lines and 2-3 blue vertical lines all pretty close to eachother. Any proposals???
    President:
  • 1,099 Answers
All plasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 02, 2010
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Lines on Sony Plasma HDTV
it can be fixed but in this case i doubt its worth fixing. these problems can be astronomically expensive and personally i would buy a nice new bravia or something similar. please rate
May 11, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Televison & Video Logo
434 people viewed this question
Top Televison & Video Experts
Electro Med Services...
