How can I fit the screw retaing ring to the new replacement front seal of my washing machine - this ring is located directly in front of the drum and fits around the seal - the front of the machine is not removeable (Model 1501AAA)?
  • 171 Answers
I have found that if you tilt the machine back against wall the drum will go back just far enough to squeeze my pudgy little fingers in there to get the job done. the front does come off on most machines but you don't want to go there.
Posted on Aug 02, 2010
Front door rubber seal
Fairly easy to do. It is held on with 2 wire rings, one on the outside edge of the seal when you open the door and when that is removed there is another one holding it to the outer drum. Removal of the lid may also help with removal of the inner ring. When refitting you press the lip of the seal over the outer drum edge and fit the retaining ring back and then do the same on the front where the door meets the seal. Just make sure the small drain holes in the seal are located at the bottom, best to look at the old one to see how it's fitted before you remove it.
Dec 27, 2012 | Electrolux Washing Machines
Fitting new door seal ,how to remove old seal and fit new seal?
Follow these steps to replace your door seal:
For all Free appliance repair videos visit ourVIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a springsystem holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in ourtutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Mar 31, 2010 | Hotpoint Aquarius WD640 Front Load...
How do i replace the door boot seal on a wm1814cw front loading washer
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Dec 01, 2009 | LG WM-1832C Front Load Washer
Replace LG washing machine seal
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Nov 09, 2009 | LG Washing Machines
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Aug 27, 2008 | Ariston Technologies AWD120 13 lb. Washer...
We have just bought a new door seal for a indesit washing machine please advise how to fit.
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Jul 18, 2008 | Indesit Washing Machines
Door lock whirlpool front loader
remove bad around door seal roll seal back at lock location remove the torx screws holding lock in pull lock out through front and remove wires reinstall in reverse..good luck with retaing band can be fun
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
