Question about Hotpoint NBXR463EBWW Electric Dryer
Went to try on the dryer and nothing! worked fine the last time I used it last week. what could be wrong?
    Brigadier General:
  • 3,301 Answers
Main thermal fuse in the rear of the machine, if this tests good,, check the safety switch on the door itself you can hold it in and turn the machine on,, if it works,, replace the plunger shaft that turns it on
Posted on Aug 02, 2010
2001 Chev Suburban remote start won't start and now with the key there is nothing.
The electronics involved are too sophisticated to diagnose without electronic kit. Call out a mobile car electronics repair company to come and test the car and tell you what is wrong.
Dec 14, 2013 | Remote Start System
Tip
Maytag Neptune Dryer Lights up (8.8)
Last week i had my Neptune dryer come up with this 8.8 error code and wouldn't start. so i called the Maytag people and they claimed there is no such error code so they sent out a tech (free of charge ) :) and he tested it and found nothing wrong and i had remembered that last week it was working fine when it was warm outside but now that it is cold below 40 deg. it does not want to work so i thought that this has something to do with the the dryer sitting in the room outside where it is cooler that it is inside so i got a heating pad and i placed it under the sensor that sits on the bottom of the dryer to see what would happen but no avail
so then i moved the heating pad to the control panel area on the back and turned on the heating pad for 20 minutes on high and came back and tried the drier and wow it now works so called the Maytag people back and they sent out a rep and i showed this to them and they were amazed on how this worked they are currently working to solve this issue
Hope this tip will help
Best regards Mike
on Jan 16, 2010 | Dryers
Gas line had to be disconnected to house last week for a gas leak repair. Everything is fixed and gas is back. Now gas dryer will not heat up. It runs fine, just no heat. Is there something I have to...
most gas dryers have what is called a ignitor on them that will glow when the unit is turned on and after they get red hot then a milivolt signal is sent back to the gas valve to open and fire up... i would check to see if the ignitor is glowing first... you will have to gain access to the bottom of unit in order to see this. you will have to remove front of dryer and most likely the tub,some of the newer maytags have a bracket that will hold the tub in place while working on it... before i did al this though it is possible there is still air in the line and will require bleeding the line at dryer... alot of people are afraid of gas but if common sense used you will be fine... you should have a gas stop at dryer gas supply line if not you need to install one. either way take a wrench and remove gas line at one of the closest connections to dryer and on purpose bleed a small amount of gas out.this will do 2 things (1) it will bleed any air in line going toward dryer and (2) confirm you still have gas pressure and gas going to dryer after your disconnection last week nothing happened to line.then reconnect and try again. if you ran dryer for an extended time it would eventually bleed the line also. not sure how long you ran it,but this will prove you still have gas at dryer . if after that no cure check the ignitor on unit to see if it is working if it is and no flame the gas regulator may be faulty after the disconnection last week/.... good luck to you
Feb 10, 2011 | Kenmore Dryers
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Nothing comes on. Outlet has power. 2 yrs 1 month old.
This sounds like the main PCB is blown. it may be worth checking the main PCB for damage and a blow fuse if you can locate one- caused likely by a power surge (maybe claim insurance), faulty dryer motor, faulty element or wiring fault in dryer. cheers
Mar 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Can't connect to internet
When you recieved the microsoft update it might have changed the drivers of the adapter in your computer. If that is the case you need to reinstall the drivers of the adapter so that it can connect to your router again. You need to identify the brand and model of your adapter to do that.
Feb 19, 2009 | Linksys Wireless-G Broadband Router
Display and all functions other than time have ceased to function
I had this problem after the battery was replaced at a jewellers. It turns out they had used the wrong battery as it only lasted a week.
May 16, 2008 | Tissot T-Touch T33759851
Sony 36" tube TV
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Aug 15, 2006 | Sony KV-27S20 27" TV
Hotpoint NBXR463EBWW Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
