Question about Vivitar 2000 Flash
I have an old Vivitar electronic flash 2000 unit for SLR cameras. It's the automatic model. I have fresh batteries in it, but the flash won't charge up. I've checked inside and all the wires and solders are intact.
  • 8 Answers
SOURCE: no 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Posted on Jan 29, 2008
  • 17 Answers
SOURCE: No power for my 'old' Vivitar 285HV Flash
I've got three 285HVs and have had this problem. Obviously, make sure the batteries are good and the door and inside terminals are not corroded. The whine sound that you usually hear is the high voltage circuit. the reason it changes pitch is that the main capacitor is charging. As the charge gets greater and greater, the pitch with go up as the circuit changes the power being fed to the capacitor. If you don't hear the "whine" then it's either the HV circuit isn't working (probably not) or the capacitor has gone bad. These things are sealed but can decay internally due to their structure. Usually this is due to the dielectric components breaking down or the electrolytic goo drying up (usually what causes it).
Sometimes, you can let it sit with good batteries and the switch on to see if it will eventually start to charge the cap. Most of the time tho, this is an indication that the capacitor or the charging circuit is dead. It can be repaired but sending it off will usually be more expensive than replacing the unit.
Be sure and rate me!!
Posted on Feb 09, 2009
  • 48 Answers
SOURCE: Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Posted on Mar 08, 2009
videotransmi
  • 105 Answers
SOURCE: my vivitar 283 flash won't turn on. I checked the
Check the contacts for the battery to make sure they are clean and shiny. Then insert 4 brand new AA batteries observing the correct polarity and try again. Also check your users manual to be sure all of your setting and connection to your camera is correct.
I hope this was a help to you and good luck!
Posted on Nov 13, 2009
  • 66 Answers
SOURCE: vivitar 285 not working
You don't need a Manual.
In 285 HV there is only one Power on/off switch.
If that switch is on and batteries are new Alkaline (like duracell-no chepo )or fully charged and working rechargebles,and yet the ready light do not come the flash has defect inside.For sure.
Posted on Mar 27, 2010
How do the batteries come out of a vivitar 102 flash
This is a wonderful flash unit that I had the privilege to own many years ago. The battery door is in front of the hot shoe. Slide it forward or in the direction of arrow and allow it to swing down. Four AA batteries should fall out or slide in depending on whether there are any already there.
Sep 25, 2014 | Vivitar Automatic Auto Electronic Flash...
How to charge vivitar dvd 1020
You don't. The camera uses 3 AA batteries. You can use rechargeable batteries, but they must be charged using a separate battery charger.
May 31, 2014 | Vivitar V3800N Zoom 35mm SLR Camera
My vivitar elect. flash does operate even sfter replacing batteries not even test button
This is very sad. I can only suggest to re-examine the battery orientation and check the contacts to see if they are bent or broken.
Feb 09, 2014 | Vivitar Electronic Flash 2000 Automatic
Camera won t turn on
What model Vivitar camera? What type(s) of batteries?
Jun 20, 2013 | Vivitar Cameras
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
Vivitar Flash 2000 - will it slave?
That sensor is what shuts the flash down when it senses the light coming back from the subject. The part you want to make it a slave is Amazon com Hot Shoe Flash Remote Control Controller Slave Trigger for...
Jan 30, 2018 | Vivitar 2000 Flash
Feb 09, 2009 | Vivitar 285HV Flash
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
What kind of battery for an XC-3 vivitar camera?
Your Vivitar XC-3 takes two MS76 or S76 batteries. BTW, some further specs for your camera:
It is basically the same of the Cosina brand, CSR model.
  • Match-LED Camera with an optional aperture-prefered automatic exposure accessory unit (servo-motor).
  • Shutter: cloth electronic, 4s-1/1000, B.
  • Flash: X-synch hot shoe, standard X and F synch at 1/60
  • Metering: stoped-down TTL or spot metering
  • Finder: split-image rangefinder and ground glass collar.
  • Auto diaphragm
  • Instant return mirror
  • Self-timer
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 16, 2008 | Photography
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Vivitar 2000 Flash Logo
98 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
