Question about Panasonic TC-32LX85 LCD TV
Panasonic tc32lx85 will not power up the screen and keeps making an odd sound clicking on and off trying to power up but never fully coming on.
    President:
  • 1,099 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Aug 02, 2010
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Computer powers up but only a grey screen appears
Use Recovery Disc to repair. You may lose everything.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
I just brought a MGF 2 days ago 1996 plate, I tried to start it but keeps making a clicking sounds, how can i make the car start please
Highly Likely to be the solenoid.
But first make sure the battery is fully charged.
Kev
Remobilise Ltd
Apr 06, 2013 | MG Cars & Trucks
47wx49e
Tell me if this is what you see: set comes on and after a few minutes (it has sound) you see a odd colored band of noise very dark and top to bottom to the right of center on the screen?
Apr 09, 2012 | Panasonic PT-47WX49 47" Rear Projection...
I HAVE A PANASONIC TC-32LX85 LCD TV IT DONT TURN THE LED DONT LIGHT NO SOUND ETC
I have a tc32lx85 tv and turned it off the other night and now it won't come on
Sep 29, 2010 | Panasonic TC-32LX85 LCD TV
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Screen suddenly turned off, makes an odd high pitched noise when it tries to turn back on. power button flashes orange
Sounds like there is a power problem if the neutral (return) wire on the power supply has become high impedance (or even disconnected) then you will get a high pitched sound coming from the TV PSU also the voltage that is presented will not be 240V which will give you the same problem.
The orange power button means standby if you fix the PSU then the TV might work again but it may have been damaged by the PSU.
Jan 07, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
Screen went black on my plasma tv
If the menu display isn't coming up either, then the odds are the power supply for the screen is the problem. Most manufactures call this a Backlight Inverter Board. Being that it's only 7 month old, it should still be under warranty by the manufacture. I would try to get it fixed by the warranty first if possible.
Oct 11, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Panasonic TC-32LX85 LCD TV Logo
653 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
