Question about Quartet gbc (660S) Projector Screen
Where can I order a "gooseneck" for an Quartet QRT550S?? Ours is cracked and would like to replace it before it goes on us.
Handlebar
where the bars meet the gooseneck (the part that goes down into the frame ) there is a bolt, Tighten it. If it still does the same thing... you need a new gooseneck because it is probably stripped.
Jul 29, 2013 | Diamondback Edgewood LX 700c Men's Hybrid...
2000 mercury grand marquis is the intake manifold plastic
YES AND THEY CRACK AND LEAK,THEIR ABOUT 280 AT PARTS STORE.
Aug 08, 2011 | 1998 Mercury Grand Marquis
Installing thermostat
im guessing your question is how to install it its pretty simple follow you upper radiator hose to were it meets the engine the matal thing it is hooked to is your goosneck, take the upper radiator hose off of the goooseneck just to make it a little easier then you will take the two bolts of the goose neck and remove the gooseneck then take the thermostate out and replace it with new one make sure you install it the right way or you will have issues then replace the gooseneck gasket and reinstall the gooseneck onto the engine im not sure of the tourqe specs but i usually just tighten them down dont give them the he man strength but snug them down, then reinstall your upper radiator hose if you lost any antifreeze replace what you lost and you should be good to go. run the engine for a while and make sure your gooseneck gasket doesnt leak and you can runn the engine long enough in the yard to make sure the thermostate is going to open when your truck gets to operating temp, youll know it opens when your trucks temp stops going up and goes back down just a little, once that happens you know you are all set and it is good to drive
Apr 21, 2011 | 1997 GMC Sierra
How to replace the thermostat
Hi, if you follow the bottom hose on your radiator to your motor, right where the hose goes is where the thermostat is. Its pretty simple to replace.
Follow the hose that goes from the top of the radiator to the top of the engine. The hose is black flexible, roughly 1.5" in diameter. This hose goes into a "gooseneck" on the top of the engine, secured with a clamp. Remove the clamp and the hose, and remove the gooseneck from the engine. The thermostat will be located underneath the gooseneck. Simply lift out the old thermostat, install the new one, and replace the gasket. Reassemble.
Take care
Aug 08, 2010 | 1994 Nissan Altima
Where is the thermostat located on a 1994 Nissan Altima GXE?
Dec 02, 2009 | 1994 Nissan Altima
Help replacing thermostat on 1995 Nissan Altima
You are describing the engine mounts bracket and its not attached to the gooseneck(so you will be alright). You would have to loosen the alternator and remove the belt for better clearance to the other bolt. Hopefully this helps
Aug 21, 2009 | 1995 Nissan Altima
Quartet gbc (660S) Projector Screen Logo
52 people viewed this question
Top Quartet gbc Televison & Video Experts
Marvin
Marvin
Are you a Quartet gbc Televison and Video Expert? Answer questions, earn points and help others
