Question about Bosch Nexxt WTMC 3300 Electric Dryer
The start button will depress but it doesn't start. Not on any selected time. It's been getting harder and harder to push it to start and we have to hold it down for a long time for the dryer to start. Now,holding forever won't make it come on.
    Scholar:
  • 32 Answers
Try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button.
2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction.
3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced. If it is still under full warranty, simply call a repairman.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Bosch certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Posted on Aug 03, 2010
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
Feb 24, 2013 | 2004 Volvo XC70
No watch instructions
- CHARACTERISTICS
1. Stopwatch: Measures up to 9 hours, 59 minutes,
59 seconds and 99 with 1 ¤ 100 second readout.
• Lap time measurement: Up to 9 lap times
can be measured. The lap time difference and
the fastest lap time are calculated and displayed
during the measurement.
2. Time/calendar display: Hour, minutes, seconds,
month, date and day of the week.
• Automatic calendar adjustment: Calendar
adjusts automatically for odd and even months
including February of leap years, but not for
February of common years.
• Time indication: Changeover between 12-
and 24-hour indications is possible.
3. Daily alarm: The alarm can be set to ring on a
24-hour basis.
4. Dual time: Time of a different time zone can be
set and displayed.
5. Stroke function: The watch can be set to beep
at a selected rate to serve as a pacemaker in
jogging, etc.
6. Countdown timer: Up to 9 hours 59 minutes
and 59 seconds can be set in seconds.
• “Lap time” refers to an elapsed time required to
cover a given section of the whole distance.
1. At the start of the activity, depress button “D” to
start the stopwatch.
2. At the end of the first lap, depress button “A”.
The first lap time and lap number are displayed,
though the second lap time is being measured
internally.
3. Depress button “A” to release the lap time before
the end of the second lap. The first lap time and
lap number disappear, and the measurement in
progress and “0” are displayed in place of the lap
time and lap number, respectively.
4. At the end of the second lap, depress button “A”.
The second lap time and lap number are displayed,
though the third lap time is being measured
internally.
5. Measurement and release of the lap time can be
repeated by depressing button “A”.
6. At the end of the activity, follow either of the two
methods below.
a. To display the final lap time, depress button
“A”. Then, depress button “A” to release the
lap time, and depress button “D” to stop the
measurement.
* The time displayed when button “D” is depressed
is not the total elapsed time of the
activity, that is, the time that elapsed from
the start until the end of the activity but the
time that elapsed from the start until the
stop of the measurement.
b. To display the total elapsed time of the activity,
depress button “D” to stop the measurement.
7. Depress button “B” to reset the stopwatch.
Stopwatch operation
Depress button “C” to show the stopwatch display.
Start Stop Restart Stop Reset
Accumulate repeatedly by
depressing button “D”.
Accumulated elapsed time measurement
D D D D B
Notes:
1. When a lap time measured is the fastest among
the lap times previously measured, a short beep
rings to signal that the memory has been updated
with the new fastest lap time.
2. The lap number counts up to “9”. After “9”, the
number returns to “1”.
• While a lap time is being displayed, depress button
“B”. With each depression of the button, the
difference between the displayed lap time and the
previous lap time is displayed in the following
order.
Latest lap time ® Lap time difference
Fastest lap time ¬
The selection of the display can be made in the
following order with each depression of button “C”.
* A flashing display mark indicates that the corresponding
function is in use.
- HOW TO USE THE STOPWATCH
• The stopwatch can measure up to 9 hours, 59
minutes, 59 seconds and 99 in 1¤ 100 seconds.
* Even if the stopwatch display is changed to another
while the measurement is in progress, it continues
counting properly. After the stopwatch is used,
however, be sure to reset it as the battery energy
is consumed enormously to shorten the battery
life.
Stopwatch display mark
Stopwatch operation
internally.
internally.
methods below.
measurement.
Notes:
Lap time difference and the fastest lap time
order.
• The lap time difference is displayed without a plus
or minus sign. Instead, the lap number of the
faster lap time is always displayed at the right of
the “–” mark.
Ex.)
Notes: 1. While the measurement in progress is shown
on the display, the lap time difference
and the fastest lap time cannot be shown
by depressing button“B”.
2. While the latest lap time, lap time difference
or the fastest lap time is shown on
the display, the display cannot be changed
to another by depressing button “C”.
* With each depression of button “A”, month and day
are displayed alternately.
* With each depression of button “D”, the display
changes over between the 12- and 24-hour indications.
1. Depress button “C” to show the time/calendar
display.
2. Depress button “B” to show the time/calendar
setting display. The second digits start flashing.
3. Selection of the digits to be adjusted (flashing)
is made in the following order by depressing
button “D”.
4. Depress button “A” to set the flashing digits.
One digit is advanced with each depression of
button “A”. Digits except seconds move quickly
by keeping button “A” depressed.
5. After all the adjustments are completed, depress
button “C” to return to the time/calendar display.
Seconds setting
When the seconds digits are flashing, depress button
“A” in accordance with a time signal. The seconds
are reset to “00” and start immediately.
Note: When setting the hour digits in the 12-hour
indication, check that AM/PM is properly
set. Only “PM” is displayed and there is no
indication for the AM setting. In the 24-
hour indication, there is no indication.
Jun 29, 2008 | Sportline 1000 Memory watch
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
I have a 2001 ford taurus and every time i push the brake pedal my brakes dont brake right and sounds like air is leaking
Is the brake pedal getting harder to depress? Also have you had any work done on the vehicle immediately prior to this problem? If the pedal is getting harder to depress it could be a failing power brake booster if your car has one. Some ABS systems are different than others
Feb 17, 2011 | 2001 Ford Taurus
How do i shoot a video on this camera? I set it on Video and depress button but it only shoots a picture. I have no manual.
You have to push the button with the red dot directly behind the camera and you will see the record selection on the top right hand side of the screen and the time couner will start to progress on the bottom right side of the screen.
If you depress the shutter button you will only take one snapshot of what you are trying to video.
hope this helps
Jul 09, 2009 | Canon PowerShot S51S Digital Camera
Hi, I need help with this brand of Roxy blue Calculator watch insurction and I got them from ebay but she dont have any booklet. I try to set the time. I can't do it so would you make simple explain to me...
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf if you change the following: C=C Mode A=Select B=Advance
Normal Time Setting 5.1 In Normal Display, hold C-Button for more three seconds and then push C-Button once. Tuesday flag and seconds digits will flash. Push B-Button once to reset the second to zero. 5.2 Push of A-Button once: Minute digits flash and advance by depression of B-Button 5.3 Push of A-Button once again: Hour digits flash and advance as above. 5.4 Push of A-Button once again: Month, digits flash and advance as above 5.5 Push of A-Button once again: Date digits flash and advance as above 5.6 Push of A-Button once again: Flag of weekday flash and advance as above 5.7 If push of C-Button during any changing time, Normal Display will be appeared
Jun 14, 2009 | Watches
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Buttons
It sounds like the dial pad has built up carbon on the circuit board. If possible, disassemble the handset, and clean the circuit board below the dial pad with alcohol. Denatured alcohol works best.
also, clean the back of the dial pad itself.
Oct 29, 2008 | Uniden EXS 9910 Phone (EXS9910-R)
LOC Error Part 2
press options and select at the same time its a saftey feature
Feb 13, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
118 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
