Question about Caroma Home
Refill water doesnt stopkeeps running - Caroma Home
  • 33 Answers
Could be that the flapper is not seating properly and lets the toilet tank slowly drain into the bowl..
clean flapper and drain to toilet in tank and verify for proper seating.
if it still runs, my opinion would be to change flapper.. (if new enough, then under warranty)
Posted on Aug 02, 2010
How do you install a heater core for a1991 Mazda Navajo
remove dash assembly try to back flush first or drain cooling system put water back in add cascade dish washing soap and drive a couple days if heater starts woreking better turn heat on high run engine open drain with a hose nozel on high and a large pan under drain flush all water out with engine running refill system with heat on high and vehicle running if heat still weak remove heater hoses the top should be the return line put a hose about 8 inces long on both out lets run the bottom hose to a high area where it can be suspended put a funnel in upper hose poor clr into hose until it comes out top of lower hose let set for hour and a half then flush out with water into a clear jug flush water vthrough upper hose then if u have air compressor have a 6 inch hose attatched to upper pipe and blow out core into same jug until the jug has clean and clear water refill cooling system and drive if heat doesnt work at first put engine under a load to release residule deposits in heater core and it should start flowing
Apr 01, 2012 | Cars & Trucks
I have 2004 toyola corolla . this sometime has air and sometime it doesnt
sounds like you have water in the ac lines, you will have to purge the system and then refill. if you do this yourself make sure to run a shot of gas through your filler hose to make sure air and moisture is removed, so you don't have the same tyhing happen again.
Mar 28, 2011 | Toyota Corolla Cars & Trucks
When you turn the engine off the overflow jug bubbles,but not when its running, and it doesnt seem too get hot???
Not enough coolant in the system. Wait until it is completely cool, refil with a 50//50 mix of antifreeze and water. Then check for leaks.
Mar 06, 2011 | 1994 Nissan Altima
I have a 1999 GMC Safari van that overheated last week.Rad was dry.I have refilled with antifreeze water mixture, van runs and has heat , no leaks under vehicle, no antifreeze smell. Van is running rough...
yes a beginner can just follow the top rad. hose to the block use a 10mm socket to take the 2 bolts out. scrape the old gasket away put new gasket and high temp silcone on gasket and install new thermostat.
doesnt sound like the problem to me, check the oil make sure no water is in it, sounds like the head is cracked on the exhaust side and ur water is going out your tailpipe, so in turn would ruin your cat converter and make the truck run raggy
Dec 13, 2010 | GMC Safari Cars & Trucks
1999 Hyndai Accent 1500 cc high cooling water temp.
over heating while stopped usually indicates that the radiator fan is not coming on ...when the engine is running hot you should be able to hear the fan running .. if it doesnt then suspect the thermal switch mounted on the radiator .. make sure the fan turns freely .. the fan is not needed when the car is moving so it wont heat up as long as you are driving .. but will do so when stopped if thats the trouble .. sometimes the thermal switch operates a relay that in turn operates the fan ..that could also cause the trouble ..
Jun 10, 2010 | 1999 Hyundai Accent
Compressor runs but coils don't get cool to shed water
if the compressor is really running (not just the fan) and it doesnt cool the evaporator coils then it has lost its refrigerant (likely r134a) .. thats a special job to repair.. there also has to be a leak that must be repaired .. then the system is refilled and possibly a dryer added .. if the fan is running only, then there are many other possibilities .. .. you shouldnt run the unit long since part of the cooling for the compressor comes from the refrigerant .. it will shorten its life if run a long time without it ..
Aug 01, 2009 | Haier HD451E Dehumidifier
The machine still show the toner empty, new toner in
this problem is mostly reported when you refill the toner incorrectly.
flush out the whole toner(not with water) just shake it upside down.
now refill it.
if it doesnt work try cleaning the terminals of toner catridge and the terminal of the printer
Jul 02, 2009 | Ricoh AC104 All-In-One Laser Printer
Ice Maker dont work
If tray is empty lets fill with water from tap and wait to see if it freezes and dumps. If yes and don't refill then I need the model number so I can help you better. It may need a water control valve or a thermostat, Thanks, Se Breeze
Jun 18, 2009 | Montgomery Ward Refrigerators
After flushing, water does not refill the tank.
yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
Isolate water service remove valve as required clean/replace re instate test & leave working
Dec 15, 2008 | Toto Carlyle 1-piece Elongated Bowl Toilet
Ink cartridge question
Try Soaking the print head in Warm water for about 3 minutes. Dry off the print head with a paper towel. If you don't see any ink on the paper towel, then the print head is clogged and it will be difficult to unclog the cartridge.
If the warm water doesnt work, then next try some Windex with amonia. Only soak the bottom of the cartridge where the ink comes out. Soak the printhead for about 3 minutes, and then try wiping off the bottom again. Press a dry paper towel on the bottom. If there is no ink then it is probably time to get a new cartridge. In the future, always try to refill your cartridge right away as soon as possible so that the ink in the cartridge/print head doesnt get a chance to dry out.
I hope this helped.
Please leave a rating if I have helped you with your question/problem.
Have a good day and good luck.
Mac =)
May 20, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Home Logo
303 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
