Question about Sony VPH D50HTU Multimedia Projector
I have a Sony VPH-D50Q (with EXB-DS10 Extender) and am using the RGB inputs (InputA??). It recieves std video (480i) just fine but when I send it 480p, 720i or 1080, it says "Input A - No Signal. Also, when I go to the Set Settings menu in Service Setting mode, it indicates that an OSC Pattern P2 and won't allow me to change it. Am I using incorrect setup settings and if so, what should they be? - Tom S
  • 7 more comments
  • tsims2 Aug 02, 2010
    The S-Video input works for STD TV but I am trying to get 720 and 1080 to it which cannot be done via S-video. It sees 480i from the RGB inputs but thinks there is no signal when fed 720 or 1080.
    I undersand the differences between composite, s-video and component video. My problem is not cables but settings on the 50Q. Is anyone out there familiar with the setup for a Sony 50Q. I have the installers manual and have used it for all setting up to this point but can't get it to see "Input A" signals which are higher video quality than 480i even though the projector is cabable of showing higher resolutions.
    thanks. Tom S..
    I am still seeking anyone with setup knowledge specifically for the Sony 50Q. Anybody out there with this specific knowledge??
    I still need someone's advice who has setup experience on the 50Q beyond focus, registration and basic settings. Specifically, how to get it to see a signal higher res than 480i into the RGB jacks on the projector. It is operating just fine except it doesn't recognize the higher res input signals.
    - Tom
    Wrong! HDMI cables are not required to get 1080. COMPONENT RGB is capable of 1080 also. I really would like to hear from anyone familiar with the 50Q.
    I have a Sony VPH-D50Q (with EXB-DS10 Extender) and am feeding it using the RGB inputs via BNC Cables (InputA??). It receives std. video (480i) just fine but when I send it 480p, 720i or 1080, it says "Input A - No Signal. Also, when I go to the Set Settings menu in Service Setting mode, it indicates an OSC Pattern P2 and won't allow me to change it.
    Settings include: In Set Settings Menu: Input A: Component, (not RGB, HDTV-YBbPr, or HDTV-GBR).
    5 BNC Mode is Off (not On). In Options: Int IDTV is On (not Off).
    - Tom S
  • tsims2 Aug 03, 2010
    I am still hopeful of finding one of your experts who has actual setup experience on a Sony D50Q Projector.
    Al (eliteprinter) was right on target with the solution. I really appreciate his help. Diskman was trying to help with a relative website.
    The other experts? were either unfamiliar with the D50Q or were not very bright when it comes to HDTV.
    - Tom
    - Tom
  • 223 Answers
HI Tom,
In order to configure the proyector for hd video you would need to change a couple of things in your set up.
First you would need to use hd cables, and not the rgb. You can purchase some standard high def cables at any best buy or radioshack, depending on the source device there is the standard high def out, the set of 5 cables, 3 video plus the 2 audio.
To enable the unit to support the progressive DVD signal, perform the following
procedure.
Connect the DVD player’s component output into Input A.
In the SET SETTING menu select HDTV-YPbPr for Input A.
In the INPUT SETTING menu highlight Sync and select EXT (HV).
The IDTV module disables itself automatically
Perform this procedure with nothing connected to the component input on the projector, otherwise you will get the an off/on flickering screen which prevents you from seing what you are doing when navigating the menu screens. Perform the procedure and then connect.
Let me know if you need anything else,
Al
Posted on Aug 03, 2010
  • 5 more comments
    Thak you Al. For some reason I missed your response to my query and have since posted another. Your suggestions sound good. I will try what you have suggested and then let you know what happens. You are right, the screen goes nuts if I have input connected and that was interfering with my ability to try different settings.
    Thanks again.
    Tom.
    Al, you're a genius. I didn't have to change cables but the settings you suggested were exactly correct. I now have 1080 projected on the big screen! Thanks again for your help! Just what I needed!
    - Tom
    - Tom
    - Tom
    - Tom
    - Tom
  • Al Toledo Aug 03, 2010
    Hi Tom,
    I was finally able to comment on the thread, I am glad that the problem was solved.
    Take care,
    Al
    President:
  • 2,559 Answers
It is trying to send Hidef signals through a non hidef connection.you will need to get a HDMI cable for this to work in 1080
Posted on Aug 02, 2010
  • Randy Hough
    Randy Hough Aug 02, 2010
    ABG (Automatic Background)
    on/off function
    To ensure that white balance is not
    affected by aging of CRTs or
    temperature drift, the VPH-D50Q/D50QM
    has an ABG circuitry individually
    controlling each CRT. However, this
    circuit can be switched off if the
    gray line produced by the ABG
    circuit at the top of the picture is
    unacceptable. This is particularly
    useful in installations such as
    planetariums and in multi-screen
    systems.
    * The ABG circuit is set to on at default
    VPH-D50Q/D50QM
    OPTICAL
    Projection system: 3 picture tubes, 3 lenses, direct projection
    system
    Picture tube: 7-inch (phosphor size 5.5-inch) static focus
    CRT
    Projection lens: Double focus, F1.0/135mm
    Screen coverage: 60 to 250-inch measured diagonally, factory
    preset to 120-inch
    Light output: ANSI*1: 160lm (fH: 64kHz, fV: 50Hz, 6500K)
    130lm (fH: 15kHz, fV: 60Hz, 6500K)
    800lm (peak white)
    200lm (all white)
    Throwing distance: 60-inch 1902mm (6 ft 2 7/8 inches)
    70-inch 2179mm (7 ft 1 25/32 inches)
    100-inch 3016mm (9 ft 10 3/4 inches)
    120-inch 3571mm (11 ft 8 19/32 inches)
    150-inch 4424mm (14 ft 6 3/16 inches)
    200-inch 5844mm (19 ft 2 3/32 inches)
    250-inch 7257mm (23 ft 9 23/32 inches)
    SIGNALS
    Color system: NTSC, PAL, SECAM, NTSC4.43, PAL-M
    Resolution: 700TV lines (video)
    1000TV lines (HDTV)
    1280 x 1024 pixel
    (RGB, measured at fH: 64kHz, fV: 60Hz)
    Scanning frequency: Horizontal: 15 to 64kHz
    Vertical: 38 to 150Hz
    RGB bandwidth: 75MHz-3dB
    GENERAL
    Power requirements: VPH-D50Q: AC 120V, 50/60Hz
    VPH-D50QM: AC 220 to 240V, 50/60Hz
    Power consumption: 450W, Standby: 7W
    Heat dissipation: 1535.7BTU
    Operating temperature: 0 to 40°C (32 to 104°F)
    Operating humidity: 35 to 85%
    Storage temperature: –20 to 60°C (–4 to 140°F)
    Storage humidity: 10 to 90%
    Dimensions: 603(W) x 345(H) x 671(D)mm
    (23 3/4 x 13 5/8 x 26 1/2 inches)
    Mass: Approx. 54kg (119 lb 1 oz)
    INPUTS/OUTPUTS
    Video: Loop-through BNC
    1Vp-p±2dB sync negative, 75½
    S Video:
    Y IN: BNC
    C IN: BNC
    Burst 0.286Vp-p±2dB (NTSC), 75½
    0.3Vp-p±2dB (PAL), 75½
    Y/C IN: Loop-through mini DIN 4-pin
    Y (luminance): 1Vp-p±2dB sync negative, 75½
    C (chrominance): Burst 0.286Vp-p±2dB (NTSC), 75½
    0.3±2dB (PAL), 75½
    Input A: BNC x 5
    Analog RGB/Component:
    R/R-Y: 0.7Vp-p±2dB positive, 75½
    G: 0.7Vp-p±2dB positive, 75½,
    G with sync/Y: 1Vp-p±2dB sync negative, 75½
    B/B-Y: 0.7Vp-p±2dB positive, 75½
    Sync/HD:
    Composite sync: 0.6 to 8Vp-p, high impedance,
    positive/negative
    Horizontal sync: 0.6 to 8Vp-p, high impedance,
    positive/negative
    VD:
    Vertical sync: 0.6 to 8Vp-p, high impedance,
    positive/negative
    HDTV*2 (Y/PB/PR):
    Y: 1Vp-p±2dB, 75½
    Tri-level sync: ±0.3Vp-p, Bi-level sync: 0.3Vp-p
    PB/PR: ±0.35Vp-p±2dB, 75½
    HDTV*2 (GBR):
    G with sync: 1Vp-p±2dB, 75½
    B/R: 0.7Vp-p±2dB, 75½
    Input B:
    Supplied with an IFB-40: 14-pin multi connector (input: male,
    output: female)
    CONTROL S
    IN PLUG IN POWER: Stereo mini-jack
    5Vp-p, plug in power DC5V,
    maximum output 60mA
    OUT: Stereo mini-jack, 5Vp-p
    REMOTE
    RS-422A: D-sub 9-pin (female)
    ABL Link
    IN: Mini-jack
    OUT: Mini-jack
    TRIG: Mini-jack
    Power On: DC5V, output impedance 4.7k½
    Power Off: 0V
    SAFETY REGULATIONS
    VPH-D50Q: UL1950, CSA950, DHHS, DNHW,
    FCC (ClassB), IC (ClassB)
    VPH-D50QM: EN60 950 (TüV), CE, PTB, C-TickMark
    ACCESSORIES
    Supplied accessories: Remote commander RM-PJ1000
    Remote commander cable (15m)
    Adjusting plate
    AA size (R6) battery x 3
    AC power cord
    Operation manual
    Installation manual
    Optional accessories: Interface board IFB-12/20/21/30/1000*3
    Extension board EXB-DS10 (internal linedoubler
    board)
    Signal interface cable SIC-
    10/20A/20B/20C/21/22/30
    SIC-M (Signal interface cable,1/5/15/25/50m)*3
    Signal interface switcher PC-1271/1271M
    Interface unit IFU-1271/1271M*3
    Suspension support PSS-70
    Suspension support PSS-10
    Remote commander RM-PJM800
    Infrared remote control receiver RM-PJ10
    Mouse receiver RM-PJ20/21*4
    Signal adapter ADP-10 (HD D-sub 15-pin to
    D-sub 9-pin for SIC cable)
    Signal adapter ADP-20 (Macintosh® to VGA)
    Monitor cable SMF-400 (HD D-sub 15-pin to
    5BNC)
    Monitor cable SMF-401 (HD D-sub 15-pin to
    HD D-sub 15-pin)
    9-pin remote cable RCC-5G/10G/30G (D-sub
    9-pin to D-sub 9-pin for RS-422A)
    100-inch flat screen VPS-100FH
    120-inch flat screen VPS-120FH
  • Randy Hough
    Randy Hough Aug 03, 2010
    Here is a setup manual link
  • 821 Answers
Hello,please kindly visit the site below for a comprehensive instruction on ho to set up your sony VPH D50Q.
www.cinemasource.com/articles/calib_video_proj.pdf
wish you goodluck,
take care.
    Thanks for the website suggestion. I downloaded and read the document. It goes through registration setup but stops short of menu settings. I need advice on setup settings.
    - Tom
    President:
  • 567 Answers
Hi the first step to solve this problem is to uninstall the drivers for Sony VPH D50Q then reinstall them again.
  • 2,272 Answers
Some cables are not compatible for the higher settings like,720i or 1080.but they will work for 480i settings. Read the procedure:-- Composite Video (Analog, limited to 480i, High Definition not possible) The lowest quality of video signal, but also one of the most common, found in everything from video games to VHS machines and DVD players. Composite is limited to 480i (standard definition) resolution. Once you’ve seen a higher end high definition signal (720p, 1080i, 1080p), chances are you’ll abandon all sources using composite video, but if you have a large collection of Beta tapes or an old video game, you’ll still need to send a composite video signal to your projector.
Most commercial grade projectors will have a BNC connector for the video connection on the input jack panel. This is a higher grade connector than the consumer RCA jack on the back of a DVD player, and Radio Shack sells a BNC to RCA adapter that will convert the connections. One trick is to use RG-6 cablevision cable as your video cable connection to the projector. That way you can run the video cable up to about 300 feet without loss of the video signal. Simply buy an RCA to F (cablevision connector) adapter at the video source end, and get a second adapter at the projector which is a BNC to F adapter. Then run your cablevision wire between the two.
S-Video (Analog, limited to 480i, High Definition not possible) One step above a composite video signal but still limited to 480i (standard definition) signals. High definition (720p, 1080i, 1080p) is not possible. Relatively speaking, I’d say that an S-Video signal is about 25% better in picture detail than a composite video signal, so wherever possible, use an S-Video feed to send to the projector over a composite video signal. Use the S-video connection will get about 20% more detail (my estimation) over a composite video connection.
Due to the black and white and chroma (color) signal being run separately within an S-video cable, the general recommended length of an S-video cable is limited to 30 feet or less. Longer runs will show that the black and white and color images will not overlap completely on the screen, and the color portion of the signal can lag the black and white one by ¼" on the screen. I’ve seen this happen in one of my own installations, and the only cure is to use a shorter S-video cable (or buy a very expensive S-video signal booster with adjustable phasing controls on it). It is very easy to bend one of the 4 pins on the S-video cable, take care not to bend a pin, or a loss of picture or color will result.
This above cable will help.
Component/YPbPr (Analog, 480i to 1080p resolutions supported):-- Component (YPbPr) signals come in varying resolutions and can support from a basic 480i standard definition video signal all the way up to 1080p high definition. High definition signals usually come in 1080i or 720p outputs from a high definition cable/satellite box and 1080i, 720p, or 1080p from HD-DVD/Blu-Ray players. Note: A component signal is NOT the same as an RGB signal even through the color coding is the same. The signals in component cables are broken up differently than those carried in an RGBHV cable so you cannot switch between the two using simple cables.
The introduction of the component signal format has caused more confusion and frustration than any other signal format. Sometime in 1994 (I’m guessing), some brilliant engineer decided that the decades old RGB industry standard for commercial and industrial video was not good enough for the consumer industry, and thus the component format was invented. Even though the three wires that are coloured red, green and blue for the component signal would indicate a plug and play connection to a display or projecto's RGB input, as component signal and RGB signal are NOT compatible. If you connect a component signal to an RGB input, you’ll only get a green image. The R and B output will be very low.
You can get required cable from
www.radioshack.com--------------
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • 4,323 Answers
Hi
I'll suggest you to use an S-Video cable or a BNC cable if you have them, to check whether it is working with them. Also, check the RGB adjustments and reset them from the RGB menu and reset it as it works with 64KHz signal only. Please visit this link and check the settings as given in the manual--
Sony VPH-D50Q User Manual
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Trying to hook up a playstation 2 to a sylvania LC195SLX tv
The PlayStation 2 may natively output video resolutions on SDTV and HDTV from 480i to 480p while other games, such as Gran Turismo 4 and Tourist Trophy are known to support upscaled 1080i resolution using any of the following standards: composite video(480i), S-Video(480i), RGB(480i/p,
Which output from the game to the TV are you using?
Apr 13, 2014 | Sylvania Televison & Video
The scrren either says resolution is not supported (mode 1) or the screen wiggles and shakes (mode 2). A directly connected pc works fine. I am sending to a tv with pc input as the remote display
The QVS VBC5 video extender supports a maximum resolution of 1600x1200 @ 60Hz for up to 50meters (164feet) & 1024x768 @ 60Hz for up to 100meters (330feet).
Make sure your maximum distance of Category 5 cable from your source to your television is no longer than 330 feet if using a 1024x768 resolution. Try dropping the resolution on your source computer in Mode 2 to resolve the issue.
Mar 29, 2011 | QVS VBC5 VGA/RGB Video CAT5e Extender ...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
The tv says that its outputing at standard 480i resolution. how do i set it to 1080i?
You have to use the RGB component inputs on the jack panel and make sure you set your cable box the same. If your using basic cable screwed into the antenna input jack then that's the max you'll get is 480i. You have to use the RGB input to get 1080i with that model.
Dec 20, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sony VPH D50Q projector doesn't see signals above 480i
HI Tom,
For some reason I cannot reply to other inquiry would you please close the problem, I am glad that the configurations worked out for you.
Al
procedure.
Al
Aug 02, 2010 | Sony VPH D50HTU Multimedia Projector
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
MY VIDEO PROJECTOR SONY VPL -HS10, CONNECTED TO COMPONENT VIDEO OUTPUTS IS DIPLAYING DATA ON THE SCREEN UPSIDE DOWN. HOW DO I CHANGE THIS PLEASE
There should be a menu option for orientation. The selection may be for ceiling vs standard. You have the unit set for ceiling mount.
Dan
Sep 12, 2009 | Sony VPH-G70Q Video Projector (VPH G70Q,...
Is the RGB computer-like jack at the rear of the Pioneer PRO-520HD projection TV a digital input like a DVI input? I'm trying to use the TV for BluRay discs. Chris Fox
The RGB input is like a computer monitor input, and may handle HD. I would recommend using component video instead for ease of use, but also most TVs will only handle a couple resolutions, but your component jack should handle 480i, 480p, 720p, and 1080i giving you flexabilty and a comprable picture.
Dec 06, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Sony VPH D50HTU Multimedia Projector Logo
310 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
