Question about RCA D52W19 52" Rear Projection Television
I have to cut it on and of many times before it starts working
  • RCA Master
  • 8,617 Answers
Replace the three capacitors CP150, COP120 and CP114. Very commoin problem you can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the Capacitors and the CD with instructions.
Posted on Aug 03, 2010
Cuts off when heated up
Its the way the carburettor works..You have not named the model and brand, but I suspect the choke is staying on after it warms up. This is an easy fix but needs to go to small repair shop
Mar 18, 2014 | Garden
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
1994 continental runs than cuts off and takes awhile to start back up?
might be the Fuel Pump Relay. They get intermittent like this. If it was never changed, I'd start there
Oct 05, 2012 | Lincoln Continental Cars & Trucks
Not cutting
Please be more specific with your question.
May 22, 2012 | Husqvarna Saws
MY CAR WILL RUN THEN CUT OFF AND NOT START THEN
It could be a fuel pump starting to go bad.
May 27, 2010 | 2004 Buick Century
My engiene cut out while driving and wont start it cranks but it wont start... i changed the ignition coil and the wires and the plugs nothing i sprayed starting fluid in the intake and nothing it cranks...
Did you check for good compression? You may have either jumped timing or have a broken timing belt. I would check engine compression first. If it's good then move on to checking your fuel and ignition systems.
Nov 03, 2009 | 2003 Dodge Neon
1991 Toyota Corolla - Cut out
It might be a broken timing belt. pull the oil filler cap and have someone try to start the engine......if there is nothing moving in there then it is confirmed. u might need a timing belt
Apr 15, 2009 | 1991 Toyota Corolla
Will cut out at speed. And then starts again.
boost too high,theres a boost cut out that interupts the engine by cutting out split seconds to stop overboosting,is it stock or has there been mods done
Mar 07, 2009 | 1995 Subaru Impreza
RCA D52W19 52" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
