How do I find out what my new IP address is and how do I reset it so my printer will work?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
I suppose that you have a network printer. If so, no matter what is your ip on the computer (this is not the issue). The thing is to know what is the IP of the printer to be able to connect to the printer thru its IP. So, there are 2 solutions.
1. Browse for a network printer (dont think it will work)
2. Local printer -Create a new port (choose IP = type the IP adress of your printer)
Posted on Aug 02, 2010
The IP address was locked and can not create a new address
Try doing a factory reset should return you back to your default settings and should remove any locks off of the IP address
Dec 24, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Printer lost static IP address with new router and won't install on network.
Your printer is looking for your old router.
Reset the printer:
  • Verify that the printer is powered on.
  • Press and hold down the Report Page button.
  • While holding down the Report Page button, press the Cancel button three times.
  • Release the Report Page button.
Now, re-connect your printer to you new router.
Source :
Re Can Get DeskJet 6840 To Work on Wireless Network Need HP Support...
Feb 12, 2014 | HP DeskJet 6840 InkJet Printer
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
IP address of printer on the network has changed
You have to use the utility call SetIP that comes with the printer. Check the CDs. It is easy to use.
May 16, 2010 | Samsung ML-2851ND Laser Printer
IP address
If you lose the IP address you can reset the network card.
Since the machine no longer has an IP address, you MUST be connected with a network cable.
1. Turn the power off
2. Press and hold the "go" button (the blue one on the front)
3. While holding the Go button, turn the power back on.
4. Keep holding the Go button until all 4 lights are on.
5. Release the "Go" button and press it 7 times quickly.
This will reset the network card and you should get a proper wired LAN IP address.
Thanks,
Pat
Mar 31, 2010 | Brother HL-2170W Laser Printer
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
Printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
Mar 24, 2008 | Dell 1710n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
