Question about Nitro Boating
Have a 02 Mercury 200hp ME200L motor. Work fine
Have a 02 Mercury 200hp ME200L motor. Work fine for 3-4 years, kept yearly maintanance on it. Last few years, having problem with slugging down when taking off after using motor. It's like when it gets to hot it doesn't want to take off. After keeping throttle down and working with it, it finally gets out of hole but very difficult. Had techs look at it in our area, but no one seems to be capable of repairing the problem. Help!
  • 5,687 Answers
I would say its the coil from the "heat sink" that it goes through after shutdown. The mechanics probably can not duplicate your "ON WATER" conditions in a shop. They probably take off the hood cover for access, run it in a tank without the load of the boat, or just use the "Muffs" with no resistance on the prop or engine at all.
You may also be fuel starved. The checkvalves in the fuellines may be allowing the fuel to siphon back to the tank. The engine takes off good until the float chambers run dry, then you are trying to pull the fuel up and there is a lag. When you are "Working with the throttle" you are regulating the throttle opening to match available fuel. Also check the fuel screens if a Tech has not done so. Would be interested to know outcome.
Posted on Aug 04, 2010
I have a 1999 200hp Yamaha outboard motor idles fine everytime I put in gear stalls at low rpm fine at high rpms and idles fine in gear loe rpms stalls
This may sound funny, but for a while, Yamaha put a steel bolt in the aluminum casing on the side of the motor. dissimilar metals caused extreme corrosion inside that affected operation. Check out Boating forums on Yamaha.
May 18, 2018 | Seloc Yamaha Mercury Mariner Outboards...
Proform 995 sel stops 2 mins into my work out. Retired it several time then the last time hit the stop bottom and it didn't stop. Pulled the safety cord and it still kept running at a high speed. My...
1) The control board motor is defectiive, you must replace.
2) The reason that Incline motor is Not working, is the same that controler board motor is faulty, Replace it
Blessing
cuadra2016@yandex.com
whatsapp:+50588611441
Oct 31, 2017 | Exercise & Fitness
My mercury sable 2002 motor Ustyle idals bad code p0316,301,303 come up changed spark plugs and wires still showing same codes what should i check now
PO301 & PO 303 are cylinder misfire in the cyclinders
indicated by the codes last number #1 & #3
Spark Plugs get replaced every 3 years or so & have
nothing to do with resolving any misfire issues, unless
they were in the motor for 80,000 miles & worn out
Spark Plug wire easily last 12 to 15 years or more &
usually only fail because they are mishanded & too often
You problem IF the codes are correct & they are not all the
time,is a bad ignition module or individual coil if that is
what you have
Jan 20, 2013 | 2002 Mercury Sable
I have a 1987 200hp johnson outboard motor. Motor runs great, I have replace the water pump, and theromstat last year. This year I replace all the fuel lines, oil lines and filter in boat. Also the spark...
Could be a faulty temperature sensor. May want to replace it. Secondly if you have an old rubber water pump impeller that was dry-rotted and lost a piece, it could actually be lodged in one of the cooling veins of the block itself. This could still allow water to spray from the tattle tale vent but an isolated area of the block could still not be getting the normal flow it should and causing the buzzer to sound out.
Oct 27, 2017 | OEM Systems Boating
Can the stock stator on an 02 ktm 520 sx suport a
Yes' I almost bought one last year that was street legal complete with turn signals tail light and headlight all running off the battery. The stock stator kept up with it all just fine. The only reason I didn't get the bike was because a Husqvarna SM 450 R was available.
Oct 30, 2009 | 2002 KTM SX 520 Racing
Aircon works fine for 5 min after starting car then funny smell and nothing but warm air. when revs kept low might come on again for few min
Check the compressor when you notice the smell. See if its running or not. It could also be the blower motor itself. I'd suggest checking the blower motor first off. Those usually only last a few years, and if it got wet some how it could have rusted or corroded on the inside. Or a wire broke on the inside and it shorts out to ground which could explain the smell.
Jul 15, 2009 | 2001 Saab 9-3
Engine compatibility for a 1996 maxda Mx-3 precidia
If you have a 4 cyl motor, that any 4cyl will fit from an MX-3 (and a few other vehicles actually).
If you have a V6, then you can use any other MX-3 1.8L OR MX-6 OR Ford Probe OR Millenia 2.5L V6 motor (160hp)! You can import the KLZE (200hp) from japan for around $1300 and it will also fit (2.5L V6).
any questions, join the forum at http://www.mx-3.com/phpBB3/index.php
Apr 08, 2009 | 1992 Mazda MX-3
Boating Logo
Top Nitro Boating Experts
fordexpert
ray gallant
Oldnwise1
Level 1 Expert
Are you a Nitro Boating Expert? Answer questions, earn points and help others
