Question about GPS
Hy there i have a boat raymarine C120 unit that does radar saunding machine,and GPS mapping. it started worked for about 15 minutes in multifunction display , then it started going off and on until only the first display pages comes on every 30 second goes blank like it usually does when first started , but it returns to the first display page , i have supplying power a 300 connection box as normal in this installation , does this machine have fuses? that could interfere with starting? gratefull for any help gimmy sola
  • 677 Answers
Hi
I have a Gps device that started rebooting after an unplanned disconnect from my PC. When looking at the files on the device using Windows Explorer I found a number of corrupted files, indicating a damaged FAT (File Allocation Table) these files could not be deleted or repaired. To resolve this I carried out the following: (1) Locate a 'Good' file backup of the device, made prior to the device causing problems! If you do not have one, you have a problem and will need to contact your dealer. (2) Connect the device to the PC via the USB lead, (3) I used Achronis Disk Director to format the device to FAT 16. (4) Copy the backed up files to the device. (5) Safely disconnect the device. (6) Reboot.....Job done. OK it's not for the faint hearted but it will resurrect your TT, the moral of the story is ALWAYS backup your device.
Posted on Aug 02, 2010
Hi I have a raymarine c120,dose the hiden electronic compass have a reset button,when following a track on screen im am traveling sideways or a stern,,,do I need a new one or reset,??
Do you have the display configured for "heading up"? If it's "north up" then the map orientation will be fixed and your heading will change. Look at the softkeys under "presentation". The C120 doesn't have a hidden electronic compass; it uses the heading from the GPS (which will wander around when you are stopped). If you have a Raymarine autopilot it will provide compass heading to the C120.
Oct 09, 2013 | Raymarine C120 System Pack C120 Raystar...
My Raymarine C 120 GPS intermittently stops working.
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Jul 28, 2010 | Raymarine C120 GPS Receiver
Even after double checks on settings Iam still getting weak echos on Raymarine E120 radar. On higher ranges picture is non existant. Where could my problem be?
How old is the radar antenna? When the echos are weak that is a sign of a failing or weak magnetron. Have you gone into the system diagnostics page to read what the signal strength of the radar is?
Jun 11, 2010 | Raymarine C120 System Pack C120 Raystar...
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
C120 Chartplotter Auto-PowerOFF
Either it's not getting enough power on the bus or there may be a problem with the unit or something hooked to it. Remove everything but power and leave the unit on. If it powers off by itself then check your voltage, if voltage ok and the leads are not corroded, send it in. If it does not power off hook things up one by one. Leave it on each time. I've seen GPS's not provided with additional power on the seatalk do this. Even though the E-series outputs power on seatalk they made a revision in this concept and now what you to power the gps externally. That may be the only problem you're having or your seatlk bus is internally breaking down.
Sep 21, 2008 | Raymarine C80 GPS Receiver
Raymarine G series radar
Your problem is likely noise from the motor. Modern diesels use high speed networks, so it could be interference. Next likelihood would be a software issue. Is the diesel set up to display info on the G display?
Solution could be re routing cables, grounding or un grounding devices. First step is to send your processor to Raymarine, sorry, necessary step to eliminate hardware failure. This is a tough symptom, so do the easy stuff first.
Jun 16, 2008 | Raymarine C80 GPS Receiver
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
C120
You might try downloading the latest C-Series update from Raymarine's site. It is version 4.26. You can get it on ther site here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1037
Even if it is identical to the software in there now, the act of actually reflashing the software may get you up and running.
Dec 29, 2007 | Raymarine E120 GPS Receiver
Raymarine C120
I don't have the sounder so can't address your question directly, but you can download all Raymarine manuals for your gear directly at www.raymarine.com
Aug 23, 2007 | Raymarine E120 GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
