Question about Panasonic Televison & Video
Panasonic TC-21PS70R /TAU54TS
I had a horizontal line across my television set and after reading all the info on your site came to the conclusion that I need to replace the Vertical Output IC. The television set has been unplugged for three days and I have taken the cover off ... heh where do I find the Vertical Output IC ... has anyone got a diagram or something? Thanks
  • 346 Answers
SOURCE: Bad vertical output IC - Only a horizontal line on CRT
check samswebsite for manua
Posted on Dec 31, 2008
Panasonic tc-l55e50
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 30, 2016 | Panasonic TC L55E50
Screen issue with Panasonic plasma tv. Model TC-P42S2.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 25, 2016 | Panasonic Televison & Video
Blue & red horizontal lines in plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2016 | Panasonic Viera TC-P50G25 50" Plasma TV
Why is there a solid horizontal green line in middle when set is on?
CCFL lamp in the back-light system fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 05, 2015 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
A horizontal band of green and red lines across the screen
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Circuit diagram TC-29P20B
Vertical scan output section circuit fault. Horizontal line problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 29, 2014 | Panasonic TC-29P22R 29" TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Horizontal lines across the lcd panel, how to fix it?
Couldn't find your model number on the Panasonic Website, however, I did locate that they have 2, 32-inch models. Try this link: http://shop.panasonic.com/shop/model/TC-L32XM6?t=tutorials&support#tabs
I would suggest clicking on the Help and Tutorials tab and follow the instructions for "How to Reset your Panasonic Veira TV". If that fails, try researching their site more or contacting their Support team for help.
Dec 23, 2013 | Panasonic Viera TX-32LX70 32 in. LCD TV
Televison & Video Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
