Question about SanDisk Sansa e250 MP3 Player
I have had my player for a while, but recently while walking the right earphone started cutting out and coming back as if something is lose. Is this a problem with the ear phones?
    Problem Solver:
  • 5 Answers
Yes the wires inside of it are damaged maybe because you wrapped the cord around the music player.
Posted on Aug 03, 2010
Have my earphones on but can not hear music
You could try using your earphones with another device to see if they are working properly. For example, I think my earphones have a broken wire in them because when the earphone plug revolves up or down in the jack the sound cuts out. When I turn the plug around a little, the sound comes back. (I am sure you had the volume turned up :)
Jul 09, 2014 | SanDisk Sansa Clip MP3 Player
Right earphone seems somewhat quieter than the left earbud. At one point, it barely made any sound at all. Recently, it's decided to make itself louder. Still, I want to fix this. The sound quality in...
Did you tried interchanging them to the other side? If the problem changes side, try any other earphones to check that the problem is still there. If it goes, the the earphone could have a problem...try to look through the hole where the sound comes from and see if it is clogged by wax or any other thing.
Feb 02, 2018 | Monster Cable Products Turbine Headphones
How do I fix skullcandy earphones? I think a wire is lose because the sound comes in and out when you move the earphone. How do you open the earphones up to fix the wires? Thank you for you time
I'm sorry to bring you bad news, but the most likely thing is that the copper conductor has become fractured inside the wire. The best you can do is to carefully identify which end of the wire has become broken (it usually happens at an end, where it goes in to an earbud, or a plug) and cut it back to the break, and then pry open the bud, cut back the insulation and re-solder the conductors. This is a pretty involved process, and to be honest, even with all the tools, I wouldn't attempt this. Oh, and plugs are usually moulded, so you can't do it, but if you try to buy a new plug in a store it will cost almost as much as new earbuds.
Feb 03, 2011 | Audio Players & Recorders
Right earphone shorting out
Good morning,
I would start off with calling Bose they do have a good warranty program and would help you.
Sep 21, 2017 | Bose QC2 Headphones
Why don't earphones when plugged not cut off itouch speaker?
i believe it has something to do with contacts with the earphones, if they are worn, it will not make a good contact to tell the external speakers to shut off...i hope this helps...maybe purchase new earphones...cheaper than replacing itouch....
Feb 21, 2009 | Apple iPod touch
Cant hear out of right ear piece
The usual cause for that is that the headphone jack is loose or the connectors are loose inside the unit and therefore not keeping complete contact with the headphone piece. It can be repaired but would probably be cheaper to get a new MP3 if that is the sansa one.
Feb 03, 2009 | Insignia Sport MP3 Player
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
Earphones stop working
I had this very problem. The Sansa worked great for over 1 year, but then I started getting some dropping out of sound on the left side. Today I went to an electronic shop and they opened up the unit. There was a small crack in the solder of the earphone jack on one side. So the electrician just used a fine point solder and fixed that, then strengthened the other solder points of the jack to make sure it won't happen again... I hooked in the earphones....and it is PERFECT again!!!! So, don't lose hope...just take it in to a decent electronics shop and they will most likely be able to fix your problem. And he only took around US$10 for the job. Beats buying a new player...
Mar 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
