Question about Uniden EXA14248 Cordless Telephone
Check for messages from outside location
I will be out of town for an extended amount of time and would like to check my phone messages. How is this done?  My manual is lost.
I found the complete manual uploaded on another site.  Thanks
Posted on Apr 26, 2008
How do you replace the brake booster on a 1989 Lincoln town car?
Remove vacuum hose from booster. Remove the two nuts holding the brake master cylinder to the booster. Carefully move booster to one side for ease of removal. Under the dashboard drivers side, remove the clip connecting the brake pedal to the booster actuator rod. Remove the two nuts holding the booster to the firewall. Outside, remove the booster. Installation is reverse of removal. There may be an adjustable rod in the replacement booster. It is important that it is adjusted properly or you may not have brakes or you could damage the master cylinder. Looking at the old booster, check to see how far the rod extends out the front of the booster. Check the new booster and make sure that the new rod extends the same distance. DO NOT ADJUST THE RODS TO THE SAME LENGTH BY PLACING THEM SIDE BY SIDE! Different designs could cause different rod length internal to the booster. What is important is the amount that extends out from the booster. This distance will not change since the master cylinder bolts directly up to the booster.
Oct 16, 2015 | Lincoln Cars & Trucks
My phone only rings 5 times before the answer function takes over. Is it possible to increase the number of rings?
The number of rings before your answring message picks up the call is controlled by your cellphone service provider. call in to your voice mail and then follow the instructions about going to options and setting. There should be a setting in there for the amount of rings to wait before answering the phone.
Feb 04, 2015 | Cell Phones
First i got a error message as "memory unsupported please update dimm1".After that i moved the ram to slot 1 after i restarted another error message showing"battery voltage is low ".what is the exact...
these can be related as the main battery on the motherboard is need to retain cmos setting when a system is unplugged from a/c power for extended periods of time.
so the loss of cmos would prompt you about certain components including amount of memory(pending no changes in memory amount/ slot location as a single chip unit must have the mem in slot 1). there is a round 3.0 volt battery that once reports bad, should be replaced. start there and see if you get any other errors. as there could be a problem with the powersupply or motherboard if that doesn't resolve it.
Jul 08, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
What town of locate use smart message centre is +639180000524
Apr 17, 2013 | Cell Phones
Static
it more than likly operats at the same frequency, move the phone or router to another location
Nov 11, 2011 | Panasonic 5.8 Ghz Cordless Phone System
Access voicemail from outside
To access your voicemail messages remotely,call your office and when the auto attendant answers enter in ** your mailbox number your password and # (**,222,1234,#). If entered correctly you will hear the amount of new and saved messages you have and also be prompted to make selections fror playing reviewing and such.
Jul 23, 2010 | NorStar T7316E Corded Phone
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
1997 Town & Country outside temperature display shows OC.
check the sensor itself it may have become disconnected, have a broken wire to it or be a bad sensor its located behind the grille
Jan 03, 2009 | 1997 Chrysler Town & Country
MOTORIZR Z3 - Message Memory Issue
One of my few complaints about my Z3 is the low message capacity. I have a 2gb sd card in there...why can't I store more than 500 texts?
But...500 is a lot more than 10, there's definitely a problem here.
I know there's a way to change the default storage location, although I'm not sure it will change the location of texts or not. Here's how to do it:
Go to the main menu and select "Settings". Scroll down to "Phone Status" and select it. Then select "Download Location" and finally, select the memory card.
Now...What concerns me the most is the 4Tb message flood O_o
Aug 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Uniden EXA14248 Cordless Telephone Logo
134 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
