Question about Olympus FE-360 Digital Camera
Cameralens does not always retract and makes noises and beeps
When I turn my camera on the lens goes out but makes almost a grinding noise and then beeps. Nothing appears on the LCD screen at all. It takes a while for the whole barrel and lens to go back in and close properly. The camera is fully charged and I'm not sure why it's doing this or how to fix it.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 02, 2010
My camera keeps turning off with a full battery and makes a beeping noise
There is something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Apr 30, 2010 | Samsung L100 Digital Camera
When I turn the camera on, it flashes E18 on the screen, makes a grinding noise and the the lens retracts
Has the camera been dropped or bumped hard?
The lens sounds like it has been knocked out of line. Had a old Kodak with the same problem. Might want to start looking for a new camera. Cheaper than repair probably.
Dec 07, 2009 | Canon PowerShot A95 Digital Camera
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
The lens will not retract and it makes a grind noise
I had the opposite problem, my lens would not full extend. It would immediately retract and turn back off. If you take a can of compressed air and blow it out as you cycle it on/off. It should clear whatever is preventing it from closing.
Here is what my problem was and how I fixed it.
What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 14, 2009 | Kodak EASYSHARE M340 Digital Camera
Lens will not retract after being
manualy try to force it down. if you hear a cruch or grinding noise that means the gears are stripped and needs to be sent in flat rate usually half what you paid originally.
Jun 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens won't close all the way
try cleaning the lens with super glue
Jul 23, 2008 | Sony Cybershot S650 Digital Camera
Black screen, lens won't retract...need help troubleshooting?!
You need to send your camera in. This is something that can't be fixed at home. Call repairs at 800-706-2534 option 2 and they can tell you where to send it.
May 31, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
The noise may indicate that there is internal damage to the tiny gears. That is not fixable, except to replace the tiny gears, a job for a tech.
See my other posts on lens problems. Trying something may make the lens to jump onto the track, not always.
Apr 24, 2008 | Nikon COOLPIX L3 Digital Camera
Beeping, bad noises, then turns itself off
If you have a retractable lens then that could be causing the problem. The beeps is letting you know that it's wrong and it shut off as a safe guard. So the noise you are hearing is the motor and gears for the lens.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Olympus FE-360 Digital Camera Logo
410 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
