Question about Motorola Mobility RAZR V3
The screen is shifted to the left and can only see half the screen.
    Problem Solver:
  • 9 Answers
This is most likely a connection/hardware issue.
A new phone is probably a good idea. Maybe your carrier offers a replacement or insurance program. If the phone is less than 30 days old, they will replace it for free. You can also send the phone off for repair, but that can get spendy, quick. This is usually the result of the wires that connect the screen to the circuit board on the bottom half of the phone, (behind the buttons) come partially loose and the imaging processor over compensates making the screen slide to the left or right and off into space.
Posted on Aug 03, 2010
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
Tip
Aero Shortcuts for windows 7
<b>[Windows] + [Spacebar] (Aero Peek)</b> Make all open windows transparent to view gadgets and icons on desktop. <br /> <br /> <b>[Windows] + [D] (Aero Peek)</b> Show or hide the desktop. <br /> <br /> <b>[Windows] + [Home] (Aero Shake)</b> Minimize all but selected window. Reverse by clicking the key combination again. <br /> <br /> <b>[Windows] + left arrow OR [Windows] + right arrow (Aero Snap)</b> Dock selected window to the left or right half of your screen. <br /> <br /> <b>[Windows] + up arrow OR [Windows] + down arrow (Aero Snap)</b> Maximized and restores the selected window. <br /> <br /> <b>[Windows] + [SHIFT] + up arrow </b>OR<b> [Windows] + [SHIFT] + down arrow (Aero Snap)</b> Maximizes and restores selected window in vertical dimension only. <br /> <br /> <b>[Windows] + [Tab] (Aero Flip)</b> Launch 3D representation of open windows and click [Tab] key again to flip through them.
on Aug 10, 2011 | Computers & Internet
Tip
Windows Management in windows 7
  1. Windows Management. By now, you’ve probably seen that Windows 7 does a lot to make window management easier: you can “dock” a window to the left or right half of the screen by simply dragging it to the edge; similarly, you can drag the window to the top of the screen to maximize it, and double-click the window top / bottom border to maximize it vertically with the same horizontal width. What you might not know is that all these actions are also available with keyboard shortcuts:
    • Win+Left Arrow and Win+Right Arrow dock;
    • Win+Up Arrow and Win+Down Arrow maximizes and restores / minimizes;
    • Win+Shift+Up Arrow and Win+Shift+Down Arrow maximizes and restores the vertical size.
    This side-by-side docking feature is particularly invaluable on widescreen monitors – it makes the old Windows way of shift-clicking on two items in the taskbar and then using the context menu to arrange them feel really painful.
on Jan 11, 2010 | Computers & Internet
I have a Kawasaki zx550A1 (GPz550), it shifts into 1st and 2nd just fine but won't shift any higher. It's almost like there is no more gears.
The bike has a bent shift fork in the transmission. You describe the classic symptoms. The engine will have to come out of the frame. Then it gets flipped upside down, right and left side covers, shift shaft, and other components are removed, then the bottom half of the gearbox is removed. This allows access to the shift drum and shift forks. There are some special tools needed and I don't recommend a novice mechanic tackles the job. Below is a diagram of how the shift drum moves the shift forks left and right to make a slider gear engage different gears. Please rate my answer. Thanks. tombones49_119.gif
Apr 27, 2011 | 1984 kawasaki Z 550 F
LG GS290 touchscreen problem I have a LG GS290 and the touchscreen has partly frozen. It seems to shift everything to the right, so when you touch 1 it activates 3. Really really annoying as you can't...
Have same problem but only shifted 1 to right ie 2 = 3 and cant use left hand keys and cant re calibrate. Turning off for a while sometmes helps but problem returns
Dec 25, 2010 | LG Cell Phones
I have hooked my Acer 1912 monitor up to my toshiba laptop as a second screen. When I select a resolution of 1280 x 1024, the display on the monitor slides over five inches to the right and I only see half...
Friend,
On the monitor go to settings and shift the screen to the left till the display is correct. However, please check for other resolutions after you have shifted. May be the monitor is not geared up to take on 1280 X 1024. Check that as well.
Aug 25, 2010 | Acer AL1912 19" LCD Monitor
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
My entire monitors display was shifted to the right (half is off screen) when I accidently pressed the auto select button instead of the off button (on the monitor) HOW can I get it BACK to where it SHOULD...
It sounds like you just shifted the whole display over. I don't know how your monitor works exactly, but you should be able to use the buttons to navigate through a simple menu system, and either pan the display back to the left, or just reset to the default settings...
Mar 21, 2010 | HP f1905e Monitor
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Hp dv6149us right half of LCD is dark, left half is OK
Sorry to say, I had a similar problem except my screen was upper/lower not left/right. If the drivers and hardware appear fine then it is the screen or connection to the screen. If under warranty send it in now! If not you may need to buy a replacement screen. Shop around for prices AND other solutions- (not being there to give it hands-on care) I may be mistaken.
Jan 30, 2009 | HP Pavilion dv6000z Notebook
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
