I just got this coffee pot. I brewed one pot and it worked great. Later, I cleaned it out, put in the water and coffee beans. When I plugged it in, it just beeps. No grinding, no brewing, just beeping. Anyone...help!!??
-   I had the same problem two different times. The first time the lid wasn't completely closed. The second time everything seemed to be in place but beeping continued. I put water into the reservoir, but added no coffee beans. All other parts were in place. Pushed "on" button still beeped, so while still in the "on" position, I carefully opened the lid only slightly...beeping stopped and grinder started...I put lid down and coffee pot went thru the cycle and heated water. Just don't try this with beans in grinder area!-   Mikethetike
Every part must be snuggly in place. I took the removable parts out and put them back a second time, and that did the trick. I must not have had everything in 'just right'.
Was this helpful?
Yes
No
Popular Solutions for Cuisinart DGB-300 Coffee Maker
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have...
(More)
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have follwed the steps in the manual. It doesn't make any noise as if attempting to grind. The grind processed is by-passed going straight into the brew mode. We used the non-grind for about 2 weeks. Thank you.
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,...
(More)
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go, but now just beeps again. All parts are in place and water is in resevoir.
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of...
(More)
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of coffee - just started doing that. Unit was cleaned 3 months ago. Fred
