Question about Dell E171FPb 17" Flat Panel LCD Monitor
Brightness pops up
The brightness menu keeps popping up without having touched the menu buttons on the front of the screen, this has been happening for about a week now. it keeps popping on and off every few secs, is there anything that can be done about this? nobody has touched the buttons on the front ever since its installation a few years back.
  • gardenmakers Oct 31, 2008
    on my dell monitor, a rectangular 'brightness' box/window keeps popping up and then dissaprearing then popping up again..sometimes i have to push the brigghtness butoon to get rid of it and other times i have to turn off the monitor and then trurn itback on to get rid of it...it is so annoying!
    HOW DO I STOP THIS!! dell has been no help at all..
    scott.
    Problem Solver:
  • 9 Answers
I know you said there were others that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
    Genius:
  • 1,554 Answers
It may just be stuck , if you push the button does it click like the others, a little wd40 around the button , lightly, may unstick it.
or you have to take the bezel off and see if the positioning is the issue.
Posted on Apr 25, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Brightness screen keeps popping up how do I make it stop?
Sounds like the tactile switch is faulty. You know on a telly remote, you press the button to select the channel....well the switches on the monitor are the same. Behind the switch is a rubber contact which has a conductive contact which you must not clean( as such) it sounds like this is in permanent contact with the conductive elements inside it. As the switch is probably only 5mm x 5mm, it is a tricky DIY job to put a new tactile switch in, but easy for someone who does electronics.
Nov 24, 2013 | Sceptre NAGA II X20WG 20 inch LCD Monitor
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Brightness menu keeps popping up
This problem is usually caused due to a faulty microswitch in the brightness button. To rectify this, you'll have to change this switch.
Get your monitor serviced by a qualified service personnel.
Hope this solves your problem. For more help or clarifications, please reply. Thanks.
Aug 09, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
Apr 04, 2007 | Acer AC711B 17" CRT Monitor
Dell E171FPb 17" Flat Panel LCD Monitor Logo
217 people viewed this question
Alun Cox
