Question about Zebra Z4M Printer
Zebra printer problem
How do I adjust the media sensor it keeps saying paper out?
    Champion:
  • Zebra Expert
  • 285 Answers
Chek on setings if the sennsor is reflective, transmissive or auto.
should be on Auto. try to read the Sensor profile, and check if read the gap.
Try the Manual calibration, and then run the sensor profile.
tur off and on again.
Posted on May 08, 2008
  • 16 Answers
Are the supplies loaded correctly? Have you calibrated it?
Posted on Apr 29, 2008
I have warning Alert : Paper out on Zebra Model S4M
Calibrate the media sensors by power cycling the printer.
If that does not fix the issue you can adjust the sensors using the following procedure.
In the menu go to advanced setup 3 and enter password (default 1234)
Select MEDIA/RIBBON CALIBRATE
Follow onscreen prompts
If this does not fix the issue you may have a bad media sensor.
ZEBRA G77752M KIT OPTICAL MEDIA SENSOR Z4M Refurbished
or Main board (I'd recommend getting a part number from the main logic board and ordering by that number as there are a number of different main logics for that printer that are not interchangeable.)
MRP provides IT Parts Product Supplies and Services
Oct 29, 2016 | Zebra Office Equipment & Supplies
My zebra printer wont line up the labels and keeps saying paper out
run the sensor profile, check if check the gap, run manual calibration, if ask for reload media, please take 3 or 4 labels from the label rolar, put through the sensors (check if ribbon(if use) is install on the correct spots and don't stop the sensors to read the gaps) and run the manual calibration.
Sep 15, 2010 | Zebra Z4M Printer
My printer says error condition paper out. But it
try to recalibrate media and sensors, run calibration, and run sensor profile, save, and restar again the printer. check if setings from the driver are correct or they can change the setings from the printer
Apr 28, 2010 | Zebra Printer 140-751-00000
Have X3 Zebra 140Xilll printers. These printers will stop printing with a message "Error condition Paper out". But the paper is loaded. Everything seems fine. What can I do? Thanks Steve Rolland
Check and clean the sensors, also the reflective surface. Make sure there are no lables stuck to the reflective surface. Use Isopropyl Alcohol to clean.
Jan 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Zebra 110Xilll Plus Printer Not Recognizing Media
You can run the manual calibration from the menu , just follow the directions. Also run the sensor profile to print out the digital representation of the media sensor .If you are using standard label stock this should tell you if the transmissive sensor is good. Depends on the media, follow the users manual if different media requirements.
Oct 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Every label printed starts further down on label zebra 105se
It sounds like the problem is with the media sensor. Make sure you haven't loaded the ribbon through the same slot that the paper enters on the media guide. There is a reflective metal plate above the media that reflects the sensor from below the media.
May 26, 2009 | Zebra 105Se Thermal Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
105SL PRINTER PAPER OUT PROBLEM
What data you are sending to the printer?Can you post it?
What Mediatype u are using(Thremal Transfre or themal Direct)?
Jun 19, 2008 | Zebra 105SL Thermal Label Printer
Printer is only printing on every other label.
Adjut the sensor or re-calibrate.
To adjust sensor:
Open up the printer where you put the label, where the paper is fed there is are two green levers, one that helps guide the paper (media guide) which is adjustable by flipping down and sliding that is located  on the right and another one that is ON the media assembly(media sensor) check this for a reference as to what I'm talking about, it's not for a Zebra but they have the same functions.
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Go to page 29 and magnify it(400%) to get a better look
depending on the type of labels you use is how to adjust
1- labels with a knotch on the side, sensor MUST be all the way on the left ( standing in front of the machine , for reference)
2-labels with a gap in between each one, MUST be set towards the Middle of the labels.
Adjust a little at a time to check by pushing the feed button
if this does not work it must be recalibrated.
I don't have a manual for that printer, sorry.
Oct 15, 2007 | Zebra S4M Thermal Label Printer
Zebra Z4M Printer Logo
465 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
