Question about KitchenAid KCMS2055SSS Microwave Oven
Door is stuck closed with food inside! - KitchenAid KCMS2055SSS Microwave Oven
Microwave heats, light come on, turntable turns, door opens/closes properly, but when heating food it starts buzzing and flickering
Replace if you are not in to DIY, sounds like the inside of the cabin has been compromised and it is now arcing. or watch this You tube video, can potentially be a fix
https://www.youtube.com/watch?v=EZmKTpaAUUQ
Dec 18, 2017 | In Microwave Ovens
Otr starts as soon as you close the door before you select any option
One of the door switches is probably defective, replacement only option.
May 31, 2012 | GE JVM1850SMSS Microwave Oven
Will not heat food
HELLO.
The solution to make your microwave oven to be able to heat food is detailed given below.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks
Sep 20, 2011 | Frigidaire Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
I have bought a corrina microwave and it is not getting hot what could be the problem
HELLO.
Thanks
Sep 18, 2011 | Microwave Ovens
How do i clean the inside of the door, it has a screen that prevents proper cleaning.
Normally the internal part of the door is not cleaned as there is a film stuck over the inside of the door stopping food and steam from entering the inside parts.
Feb 27, 2011 | Maytag MMV1153A Microwave Oven
My microwave does not heat up food, it looks ok buy does not heat up at all
Please check your door safety interlock switches. Find them inside on the side opposite the hinge. If they measure open both with the door open and the door closed, they must be replaced. You are looking for one or more micro switches.
These switches are how the device knows whether the door is open or not - forget what YOU know about the door - the device must know the door is closed in order to turn on the heat.
Thanks for your question at FixYa.com
Dec 21, 2009 | GE JVM1630 Microwave Oven
Please help me
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Jan 02, 2009 | Sharp R-242 Microwave Oven
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
KitchenAid KCMS2055SSS Microwave Oven Logo
27 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
