Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
  • 2,632 Answers
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Posted on Aug 02, 2010
Internet
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 25, 2011 | Nintendo DSi Black Console
Connecting to Wifi at home. Error Code 51102 What
A WEP key is a Security code but for some wireless providors a WPA-TKIP or WPA"-TKIp is used instead. check your connection details to find out which one yours uses and the use the appropriate settings.
Important notes would be that if your connection is using WPA-TKIP or WPA2-TKIP then the DS or DS lite will not be able to connect because they can only use WEP keys. If the system you are using is the Nindento DSi then all you need to do is to use connections 4, 5 and 6 found in Advanced Conection Settings under the internet option in the DSi Settings menu ( remember this method is only for use with other wireless securities than WEP keys like WPA-TKIP and WPA2-TKIP.)
Apr 03, 2011 | Nintendo DS Lite
How do i set my son dsi up for the internet
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon
  3. Go to the third page and select the internet button
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
  9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Mar 16, 2011 | Nintendo DSi Black Console
I have a dsi.The problem is I don't know how to connect my dsi to the internet.
Jan 18, 2011 | Nintendo DSi Blue Console
How to get internet on dsi
Jan 04, 2011 | Nintendo DSi White Console
How do you get internet on dsi \
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only). Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Hope this helps
Nov 30, 2010 | Nintendo DS Lite Console
My dsi console wont connect to wireless connection error code3 051300 my network is a bthome hub 2
You need to get your hubs wireless settings up, to do this type bthomehub.home in the address bar of your internet browser, you will then be propted for your hubs username and password which can be found on the back of the hub unless you changed it in which case you will have to use those instead.
Click on settings and choose wireless-
Make sure you have the following settings applied:
1) Interface type: 802.11b, g or n (as far as im aware the DSi wont work with n so either have the mixed (b,g or n) or just b)
2) Encryption Type: TKIP
3) Authentication: WEP or WPA
First try the WPA as its more secure but if you have no luck try the WEP with a 128 bit key first and if it don't work try a 64 bit key.
Hope this helps, any further problems feel free to contact me via my profile page and I will do my best to help you.
Regards,
SOD69
Jan 24, 2010 | Nintendo DSi White Console
Iphone 3G-S will not connnect to BT Home Hub 2.0
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub.
Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting.
Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether.
Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect.
Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Aug 06, 2009 | Apple iPhone 3GS Black (16 GB)
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Computers & Internet Logo
348 people viewed this question
Alun Cox
David Payne
David Payne
